I am trying to figure out how to set up Epson L3150.
I came from debian where I used to install something like epson-printer-escpr and then add the printer via cups or system-config-printer and it works.
I could also install the driver directly from Epson site but there is none specific to arch/manjaro linux"
I found a page aur archlinux / packages / epson-inkjet-printer-escpr but the link seems to get back to epson driver page and I have no idea how to make use of it.
For the scanner function of the printer, I have already tried simple-scan and it could find the scanner right away.
Is there any proper and clean way to do this? Please someone give some advice.
I believe the driver you are looking for, is epson-inkjet-printer-escpr:
$ pamac search epson-inkjet-printer-escpr
epson-inkjet-printer-escpr 1.7.21-1 AUR
Epson Inkjet Printer Driver (ESC/P-R) for Linux
And that can be easily installed using:
pamac build epson-inkjet-printer-escpr
Now, I don’t know if you’ll need to reinstall for different kernels, as it’s not a dkms package, but I suspect so.
As for the scanner, it would seem you need the epsonscan2 driver from the AUR:
$ pamac build epsonscan
epsonscan2 6.6.42.0-1 AUR
Epson scanner management utility
Which can be installed using:
pamac build epsonscan2
The same goes as for the printer and kernel upgrades.
Hope this helps!
Thank you for your warm welcome.
My typing of pamac search epson-inkjet-printer-escpr on terminal didn’t seem to return anything at all. However, the build command did show up a lot. That’s rather difficult for someone new to know whether pamac did find something for the search or not. What do I need to set to make it search and return something.
On scanner, I have only tried the simple scan. I used to have that epsonscan2 in debian too. The problem here again seems to come from the fact that I couldn’t get pamac to search anything.
Btw, I also tried typing epson-inkjet-printer-escpr in pamac gui and nothing found there.
I read somewhere on Manjaro official page not recommending the use of AUR so I probably won’t mess with it. Thanks for reminding me on this.
I found this.
pamac search -a escpr
epson-inkjet-printer-escpr2 1.1.52-1 AUR
Epson Inkjet Printer Driver 2 (ESC/P-R) for Linux
epson-inkjet-printer-escpr 1.7.22-1 AUR
It seems I can’t get away from AUR. But I still wonder why your typing search is different from mine that I needs to specify more options.
