I have an expired ssl cert that needs to be removed.
My question is if I remove it from /etc/ca-certificates/trust-source/anchors/my_cert.crt
and also remove its entry from /etc/ca-certificates/extracted/ca-bundle.trust.crt
, and finally run sudo update-ca-trust -f
- Will that do the job?
- Is that the appropriate way to remove an expired ssl cert and all of its traces?
