Hello!
I have two external HDDs in a docking station, and every time I poweroff my PC, these disks spin up. It’s undesirable because the docking station is incapable of spindown them and they continue running throughout the night.
One workaround I found is running hd-idle
manually and then putting the computer to sleep, but it’s not a great solution (sleep mode in some way disrupts CUDA functionality, so I need to reboot on every PC wakeup).
Initially, I presumed that the spinning up of the disks was triggered by fsck
, but changing fs_passno
from 2 to 0 in fstab did’nt change anything. Nevertheless, there are symlinks to the HDD directories in the rootfs, so if there is a solution to avoid fsck only during shutdown (how can this be achieved?), I would be eager to test it.
I hope there is some way to shutdown correctly - without spinning up the disks. Please advise on how to achieve this.
/etc/fstab
UUID=49AA-209B /boot/efi vfat umask=0077 0 2
UUID=2ed17d7a-5df9-40b9-90a0-41a168065073 swap swap noatime 0 0
UUID=4e50ff9a-cdcd-4307-85ec-3404ccfb3235 / ext4 noatime 0 1
UUID=659dffba-e49c-4b9b-81fc-c256eda691ca /hdd ext4 noatime,nofail 0 0
UUID=85144587-e9a2-47f2-bd77-a32d60a512a3 /hdd2 ext4 noatime,nofail 0 0
UUID=204F06A32A969525 /sata-ssd ntfs noatime 0 0
UUID=c9139686-4d28-43ad-b385-31bd065e584f /sata-ssd2 ext4 noatime 0 2
UUID=3fbbd346-be2d-489b-902e-cf7e8de995fb /gen3-ssd ext4 noatime 0 2
tmpfs /home/yar85/.cache/google-chrome/Default tmpfs noatime,nodev,noexec,nosuid,size=1g 0 0
sudo LC_ALL=C journalctl -b -1
(partial):
Nov 07 07:51:06 home systemd-logind[1088]: The system will power off now!
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 6 matched rules; type="method_call", sender=":1.1" (uid=0 pid=1088 comm="/usr/lib/systemd/systemd-logind") interface="org.freedesktop.DBus.Properties" member="Get" error name="(unset)" requested_reply="0" destination="org.freedesktop.systemd1" (uid=0 pid=1 comm="/sbin/init")
Nov 07 07:51:06 home systemd-logind[1088]: System is powering down.
Nov 07 07:51:06 home dbus-daemon[1376]: [session uid=1000 pid=1376] Activating service name='org.freedesktop.Notifications' requested by ':1.10' (uid=1000 pid=1477 comm="/usr/bin/kded5")
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 5 matched rules; type="method_call", sender=":1.1" (uid=0 pid=1088 comm="/usr/lib/systemd/systemd-logind") interface="org.freedesktop.systemd1.Manager" member="StartUnit" error name="(unset)" requested_reply="0" destination="org.freedesktop.systemd1" (uid=0 pid=1 comm="/sbin/init")
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.2" (uid=0 pid=1 comm="/sbin/init") interface="org.freedesktop.DBus" member="GetConnectionUnixUser" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.2" (uid=0 pid=1 comm="/sbin/init") interface="org.freedesktop.DBus" member="AddMatch" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.2" (uid=0 pid=1 comm="/sbin/init") interface="org.freedesktop.DBus" member="GetNameOwner" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home sddm-helper[1350]: Signal received: SIGTERM
Nov 07 07:51:06 home systemd[1]: Stopping Session 1 of User yar85...
Nov 07 07:51:06 home sddm[1341]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Nov 07 07:51:06 home sddm[1341]: Auth: sddm-helper (--socket /tmp/sddm-auth-2fed07c7-79f7-43c1-8ea8-b50f77905ae3 --id 1 --start /usr/bin/startplasma-x11 --user yar85 --autologin) crashed (exit code 1)
Nov 07 07:51:06 home sddm[1341]: Auth: sddm-helper exited with 1
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 4 matched rules; type="method_call", sender=":1.1" (uid=0 pid=1088 comm="/usr/lib/systemd/systemd-logind") interface="org.freedesktop.systemd1.Scope" member="Abandon" error name="(unset)" requested_reply="0" destination="org.freedesktop.systemd1" (uid=0 pid=1 comm="/sbin/init")
Nov 07 07:51:06 home systemd[1355]: plasma-kwin_x11.service: Consumed 3.512s CPU time.
Nov 07 07:51:06 home systemd[1]: Removed slice Slice /system/getty.
Nov 07 07:51:06 home systemd[1]: Removed slice Slice /system/modprobe.
Nov 07 07:51:06 home systemd[1]: Stopped target Graphical Interface.
Nov 07 07:51:06 home systemd[1]: Stopped target Multi-User System.
Nov 07 07:51:06 home systemd[1]: Stopped target Login Prompts.
Nov 07 07:51:06 home systemd[1]: Stopped target Sound Card.
Nov 07 07:51:06 home systemd[1]: Stopped target Timer Units.
Nov 07 07:51:06 home systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Nov 07 07:51:06 home systemd[1]: fstrim.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Discard unused filesystem blocks once a week.
Nov 07 07:51:06 home systemd[1]: logrotate.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Daily rotation of log files.
Nov 07 07:51:06 home systemd[1]: man-db.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Daily man-db regeneration.
Nov 07 07:51:06 home systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Monthly clean packages cache.
Nov 07 07:51:06 home systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Generate mirrorlist weekly.
Nov 07 07:51:06 home systemd[1]: pkgfile-update.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped pkgfile database update timer.
Nov 07 07:51:06 home systemd[1]: plocate-updatedb.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Update the plocate database daily.
Nov 07 07:51:06 home systemd[1]: shadow.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Daily verification of password and group files.
Nov 07 07:51:06 home systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Nov 07 07:51:06 home systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Closed LVM2 poll daemon socket.
Nov 07 07:51:06 home systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Nov 07 07:51:06 home systemd[1]: Unmounting /hdd...
Nov 07 07:51:06 home systemd[1]: Unmounting /hdd2...
Nov 07 07:51:06 home systemd[1]: Stopping AmneziaVPN Service...
Nov 07 07:51:06 home ModemManager[1224]: <msg> caught signal, shutting down...
Nov 07 07:51:06 home systemd[1]: Stopping Modem Manager...
Nov 07 07:51:06 home systemd[1]: Stopping Save/Restore Sound Card State...
Nov 07 07:51:06 home avahi-daemon[1082]: Got SIGTERM, quitting.
Nov 07 07:51:06 home avahi-daemon[1082]: Leaving mDNS multicast group on interface enp5s0.IPv6 with address fe80::ac20:6693:51cb:49ae.
Nov 07 07:51:06 home systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Nov 07 07:51:06 home avahi-daemon[1082]: Leaving mDNS multicast group on interface enp5s0.IPv4 with address 192.168.0.2.
Nov 07 07:51:06 home systemd[1]: Stopping Command Scheduler...
Nov 07 07:51:06 home crond[1340]: (CRON) INFO (Shutting down)
Nov 07 07:51:06 home avahi-daemon[1082]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Nov 07 07:51:06 home systemd[1]: Stopping CUPS Scheduler...
Nov 07 07:51:06 home avahi-daemon[1082]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Nov 07 07:51:06 home avahi-daemon[1082]: avahi-daemon 0.8 exiting.
Nov 07 07:51:06 home systemd[1]: Stopping Hard drive idling daemon...
Nov 07 07:51:06 home systemd[1]: Stopping Initialize hardware monitoring sensors...
Nov 07 07:51:06 home (modprobe)[2523]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Nov 07 07:51:06 home systemd[1]: Starting Generate shutdown-ramfs...
Nov 07 07:51:06 home systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Nov 07 07:51:06 home alsactl[2521]: /usr/bin/alsactl: get_control:255: Cannot read control '3,0,0,Playback Channel Map,0': Invalid argument
Nov 07 07:51:06 home sddm[1341]: Signal received: SIGTERM
Nov 07 07:51:06 home systemd[1]: Stopping Simple Desktop Display Manager...
Nov 07 07:51:06 home kded5[1477]: The X11 connection broke (error 1). Did the X11 server die?
Nov 07 07:51:06 home snapd[1087]: main.go:151: Exiting on terminated signal.
Nov 07 07:51:06 home kded5[1477]: kf.notifications: Had queued notifications on destruction. Was the eventloop running?
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.14" (uid=0 pid=1341 comm="/usr/bin/sddm") interface="org.freedesktop.DBus" member="RemoveMatch" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home sddm[1341]: Display server stopping...
Nov 07 07:51:06 home systemd[1]: Stopping Snap Daemon...
Nov 07 07:51:06 home kded5[1477]: kf.notifications: Playing audio notification failed: Destroyed
Nov 07 07:51:06 home kglobalaccel5[1498]: The X11 connection broke (error 1). Did the X11 server die?
Nov 07 07:51:06 home kactivitymanagerd[1525]: The X11 connection broke (error 1). Did the X11 server die?
Nov 07 07:51:06 home imwheel[1796]: X connection to :0 broken (explicit kill or server shutdown).
Nov 07 07:51:06 home xdg-desktop-portal-kde[1529]: The X11 connection broke (error 1). Did the X11 server die?
Nov 07 07:51:06 home kglobalaccel5[1498]: The X11 connection broke: I/O error (code 1)
Nov 07 07:51:06 home kscreen_backend_launcher[1662]: The X11 connection broke (error 1). Did the X11 server die?
Nov 07 07:51:06 home systemd[1]: Stopping Load/Save OS Random Seed...
Nov 07 07:51:06 home espanso[1741]: XIO: fatal IO error 11 (Ресурс временно недоступен) on X server ":0"
Nov 07 07:51:06 home espanso[1741]: after 66 requests (66 known processed) with 15 events remaining.
Nov 07 07:51:06 home systemd[1]: Stopping Disk Manager...
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.26" (uid=0 pid=1439 comm="/usr/lib/udisks2/udisksd") interface="org.freedesktop.DBus" member="RemoveMatch" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home at-spi-bus-launcher[1945]: X connection to :0 broken (explicit kill or server shutdown).
Nov 07 07:51:06 home systemd[1]: Stopping Daemon for power management...
Nov 07 07:51:06 home kglobalaccel5[1498]: XIO: fatal IO error 25 (Неприменимый к данному устройству ioctl) on X server ":0"
Nov 07 07:51:06 home kglobalaccel5[1498]: after 8 requests (8 known processed) with 0 events remaining.
Nov 07 07:51:06 home kaccess[1848]: The X11 connection broke (error 1). Did the X11 server die?
Nov 07 07:51:06 home kernel: EXT4-fs (dm-9): unmounting filesystem 85144587-e9a2-47f2-bd77-a32d60a512a3.
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.26" (uid=0 pid=1439 comm="/usr/lib/udisks2/udisksd") interface="org.freedesktop.DBus" member="ReleaseName" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.31" (uid=0 pid=1487 comm="/usr/lib/upowerd") interface="org.freedesktop.DBus" member="RemoveMatch" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home udisksd[1439]: udisks daemon version 2.10.1 exiting
Nov 07 07:51:06 home espanso[1733]: 07:51:06 [daemon(1733)] [ERROR] received unexpected exit code from worker 1, exiting
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.4" (uid=0 pid=1187 comm="/usr/bin/NetworkManager --no-daemon") interface="org.freedesktop.DBus" member="RemoveMatch" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home systemd[1355]: plasma-kglobalaccel.service: Main process exited, code=exited, status=1/FAILURE
Nov 07 07:51:06 home systemd[1355]: plasma-kglobalaccel.service: Failed with result 'exit-code'.
Nov 07 07:51:06 home systemd[1355]: plasma-kscreen.service: Main process exited, code=exited, status=1/FAILURE
Nov 07 07:51:06 home systemd[1355]: plasma-kscreen.service: Failed with result 'exit-code'.
Nov 07 07:51:06 home espanso[1723]: thread 'main' panicked at 'failed to launch daemon: unexpected error, 'espanso daemon' returned a non-zero exit code.', espanso/src/cli/launcher/mod.rs:213:45
Nov 07 07:51:06 home espanso[1723]: note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Nov 07 07:51:06 home systemd[1355]: app-org.moson.matray@autostart.service: Main process exited, code=exited, status=1/FAILURE
Nov 07 07:51:06 home systemd[1355]: app-org.moson.matray@autostart.service: Failed with result 'exit-code'.
Nov 07 07:51:06 home kernel: EXT4-fs (dm-8): unmounting filesystem 659dffba-e49c-4b9b-81fc-c256eda691ca.
Nov 07 07:51:06 home systemd[1]: avahi-daemon.service: Deactivated successfully.
Nov 07 07:51:06 home systemd[1355]: espanso.service: Main process exited, code=exited, status=101/n/a
Nov 07 07:51:06 home systemd[1355]: espanso.service: Failed with result 'exit-code'.
Nov 07 07:51:06 home systemd[1355]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=exited, status=1/FAILURE
Nov 07 07:51:06 home systemd[1355]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.7" (uid=0 pid=1224 comm="/usr/bin/ModemManager") interface="org.freedesktop.DBus" member="ReleaseName" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home NetworkManager[1187]: <info> [1699332666.7771] modem-manager: ModemManager no longer available
Nov 07 07:51:06 home ModemManager[1224]: <msg> ModemManager is shut down
Nov 07 07:51:06 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.7" (uid=0 pid=1224 comm="/usr/bin/ModemManager") interface="org.freedesktop.DBus" member="RemoveMatch" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:06 home systemd[1355]: app-kaccess@autostart.service: Main process exited, code=exited, status=1/FAILURE
Nov 07 07:51:06 home systemd[1355]: app-kaccess@autostart.service: Failed with result 'exit-code'.
Nov 07 07:51:06 home systemd[1355]: plasma-kactivitymanagerd.service: Main process exited, code=exited, status=1/FAILURE
Nov 07 07:51:06 home systemd[1355]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Nov 07 07:51:06 home systemd[1355]: app-easyeffects\x2dservice@autostart.service: Main process exited, code=exited, status=1/FAILURE
Nov 07 07:51:06 home systemd[1355]: app-easyeffects\x2dservice@autostart.service: Failed with result 'exit-code'.
Nov 07 07:51:06 home mkinitcpio[2524]: ==> Starting build: 'none'
Nov 07 07:51:06 home mkinitcpio[2524]: -> Running build hook: [sd-shutdown]
Nov 07 07:51:06 home systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Nov 07 07:51:06 home systemd[1355]: plasma-kded.service: Main process exited, code=exited, status=1/FAILURE
Nov 07 07:51:06 home systemd[1355]: plasma-kded.service: Failed with result 'exit-code'.
Nov 07 07:51:06 home systemd[1]: hd-idle.service: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped Hard drive idling daemon.
Nov 07 07:51:06 home systemd[1]: ModemManager.service: Deactivated successfully.
Nov 07 07:51:06 home libddcutil[2440]: busno=7, sleep-multiplier = 2,00. Testing for supported feature 0x10 returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_READ_ALL_ZERO(10)]
Nov 07 07:51:06 home systemd[1]: Stopped Modem Manager.
Nov 07 07:51:06 home systemd[1]: AmneziaVPN.service: Deactivated successfully.
Nov 07 07:51:06 home systemd[1]: Stopped AmneziaVPN Service.
Nov 07 07:51:06 home systemd[1]: cups.service: Deactivated successfully.
Nov 07 07:51:06 home mkinitcpio[2524]: ==> Build complete.
Nov 07 07:51:06 home systemd[1]: Stopped CUPS Scheduler.
Nov 07 07:51:06 home systemd[1]: cronie.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped Command Scheduler.
Nov 07 07:51:07 home systemd[1]: udisks2.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped Disk Manager.
Nov 07 07:51:07 home systemd[1]: rtkit-daemon.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Nov 07 07:51:07 home systemd[1]: upower.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped Daemon for power management.
Nov 07 07:51:07 home systemd[1]: hdd2.mount: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Unmounted /hdd2.
Nov 07 07:51:07 home systemd[1]: alsa-restore.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped Save/Restore Sound Card State.
Nov 07 07:51:07 home systemd[1]: lm_sensors.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped Initialize hardware monitoring sensors.
Nov 07 07:51:07 home systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Finished Generate shutdown-ramfs.
Nov 07 07:51:07 home systemd[1]: systemd-random-seed.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped Load/Save OS Random Seed.
Nov 07 07:51:07 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.2" (uid=0 pid=1 comm="/sbin/init") interface="org.freedesktop.DBus" member="RemoveMatch" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:07 home systemd[1]: session-1.scope: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped Session 1 of User yar85.
Nov 07 07:51:07 home systemd[1]: session-1.scope: Consumed 1.600s CPU time.
Nov 07 07:51:07 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.2" (uid=0 pid=1 comm="/sbin/init") interface="org.freedesktop.DBus" member="GetConnectionUnixUser" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:07 home systemd-logind[1088]: Session 1 logged out. Waiting for processes to exit.
Nov 07 07:51:07 home dbus-daemon[1083]: [system] Would reject message, 6 matched rules; type="method_call", sender=":1.1" (uid=0 pid=1088 comm="/usr/lib/systemd/systemd-logind") interface="org.freedesktop.DBus.Properties" member="Get" error name="(unset)" requested_reply="0" destination="org.freedesktop.systemd1" (uid=0 pid=1 comm="/sbin/init")
Nov 07 07:51:07 home systemd[1]: Stopping Authorization Manager...
Nov 07 07:51:07 home systemd[1]: Stopping User Manager for UID 1000...
Nov 07 07:51:07 home systemd-logind[1088]: Removed session 1.
Nov 07 07:51:07 home systemd[1355]: Activating special unit Exit the Session...
Nov 07 07:51:07 home systemd[1355]: Stopped target Main User Target.
Nov 07 07:51:07 home systemd[1355]: Stopping Geoclue Demo agent...
Nov 07 07:51:07 home systemd[1355]: Stopping AppImageLauncher daemon...
Nov 07 07:51:07 home systemd[1]: polkit.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1355]: Stopping Accessibility services bus...
Nov 07 07:51:07 home systemd[1355]: Stopping D-Bus User Message Bus...
Nov 07 07:51:07 home systemd[1355]: Stopping User preferences database...
Nov 07 07:51:07 home systemd[1355]: Stopped espanso.
Nov 07 07:51:07 home systemd[1355]: Stopping GNOME Keyring daemon...
Nov 07 07:51:07 home systemd[1355]: Stopping Virtual filesystem service...
Nov 07 07:51:07 home systemd[1355]: Stopping Bluetooth OBEX service...
Nov 07 07:51:07 home obexd[1661]: Terminating
Nov 07 07:51:07 home systemd[1355]: Stopping PipeWire PulseAudio...
Nov 07 07:51:07 home systemd[1355]: Stopping Portal service...
Nov 07 07:51:07 home systemd[1355]: Stopping flatpak document portal service...
Nov 07 07:51:07 home systemd[1355]: Stopping sandboxed app permission store...
Nov 07 07:51:07 home systemd[1355]: Stopping Baloo File Indexer Daemon...
Nov 07 07:51:07 home systemd[1355]: Stopped AppImageLauncher daemon.
Nov 07 07:51:07 home systemd[1355]: Stopped GNOME Keyring daemon.
Nov 07 07:51:07 home systemd[1355]: Stopped flatpak document portal service.
Nov 07 07:51:07 home systemd[1355]: Stopped sandboxed app permission store.
Nov 07 07:51:07 home systemd[1355]: Stopped User preferences database.
Nov 07 07:51:07 home systemd[1355]: Stopped Bluetooth OBEX service.
Nov 07 07:51:07 home systemd[1355]: Stopped PipeWire PulseAudio.
Nov 07 07:51:07 home systemd[1355]: Stopped Geoclue Demo agent.
Nov 07 07:51:07 home systemd[1355]: Stopped Virtual filesystem service.
Nov 07 07:51:07 home systemd[1355]: Stopped Powerdevil.
Nov 07 07:51:07 home systemd[1355]: plasma-powerdevil.service: Consumed 1.449s CPU time.
Nov 07 07:51:07 home systemd[1355]: Stopped target Current graphical user session.
Nov 07 07:51:07 home systemd[1355]: Stopping Multimedia Service Session Manager...
Nov 07 07:51:07 home systemd[1355]: Stopped D-Bus User Message Bus.
Nov 07 07:51:07 home systemd[1355]: Stopped Portal service.
Nov 07 07:51:07 home wireplumber[1628]: stopped by signal: Завершено
Nov 07 07:51:07 home wireplumber[1628]: disconnected from pipewire
Nov 07 07:51:07 home systemd[1]: Stopped Authorization Manager.
Nov 07 07:51:07 home systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Nov 07 07:51:07 home systemd[1355]: Stopped Multimedia Service Session Manager.
Nov 07 07:51:07 home systemd[1355]: Stopped Baloo File Indexer Daemon.
Nov 07 07:51:07 home systemd[1355]: kde-baloo.service: Consumed 3.303s CPU time.
Nov 07 07:51:07 home systemd[1355]: Removed slice User Background Tasks Slice.
Nov 07 07:51:07 home systemd[1355]: background.slice: Consumed 15.170s CPU time.
Nov 07 07:51:07 home systemd[1355]: Stopping PipeWire Multimedia Service...
Nov 07 07:51:07 home systemd[1355]: Stopped PipeWire Multimedia Service.
Nov 07 07:51:07 home systemd[1]: Unmounted /run/user/1000/gvfs.
Nov 07 07:51:07 home systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Unmounted /run/user/1000/doc.
Nov 07 07:51:07 home systemd[1355]: Stopped Accessibility services bus.
Nov 07 07:51:07 home systemd[1355]: Removed slice User Core Session Slice.
Nov 07 07:51:07 home systemd[1355]: session.slice: Consumed 12.192s CPU time.
Nov 07 07:51:07 home systemd[1355]: Stopped target Basic System.
Nov 07 07:51:07 home systemd[1355]: Stopped target Paths.
Nov 07 07:51:07 home systemd[1355]: Stopped target Sockets.
Nov 07 07:51:07 home systemd[1355]: Stopped target Timers.
Nov 07 07:51:07 home systemd[1355]: Closed D-Bus User Message Bus Socket.
Nov 07 07:51:07 home systemd[1355]: Closed GnuPG network certificate management daemon.
Nov 07 07:51:07 home systemd[1355]: Closed GCR ssh-agent wrapper.
Nov 07 07:51:07 home systemd[1355]: Closed GNOME Keyring daemon.
Nov 07 07:51:07 home systemd[1355]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Nov 07 07:51:07 home systemd[1355]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Nov 07 07:51:07 home systemd[1355]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Nov 07 07:51:07 home systemd[1355]: Closed GnuPG cryptographic agent and passphrase cache.
Nov 07 07:51:07 home systemd[1355]: Closed p11-kit server.
Nov 07 07:51:07 home systemd[1355]: Closed PipeWire PulseAudio.
Nov 07 07:51:07 home systemd[1355]: Closed PipeWire Multimedia System Sockets.
Nov 07 07:51:07 home systemd[1355]: Removed slice User Application Slice.
Nov 07 07:51:07 home systemd[1355]: app.slice: Consumed 11.210s CPU time.
Nov 07 07:51:07 home systemd[1355]: Reached target Shutdown.
Nov 07 07:51:07 home systemd[1355]: Finished Exit the Session.
Nov 07 07:51:07 home systemd[1355]: Reached target Exit the Session.
Nov 07 07:51:07 home sddm[1341]: Display server stopped.
Nov 07 07:51:07 home sddm[1341]: Running display stop script ("/usr/share/sddm/scripts/Xstop")
Nov 07 07:51:07 home (sd-pam)[1356]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[yar85] ruser=[<unknown>] rhost=[<unknown>]
Nov 07 07:51:07 home systemd[1]: user@1000.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped User Manager for UID 1000.
Nov 07 07:51:07 home systemd[1]: user@1000.service: Consumed 39.364s CPU time.
Nov 07 07:51:07 home systemd[1]: sddm.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped Simple Desktop Display Manager.
Nov 07 07:51:07 home systemd[1]: sddm.service: Consumed 3.537s CPU time.
Nov 07 07:51:07 home systemd[1]: Stopping User Login Management...
Nov 07 07:51:07 home systemd[1]: Stopping Permit User Sessions...
Nov 07 07:51:07 home systemd[1]: Stopping User Runtime Directory /run/user/1000...
Nov 07 07:51:07 home systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped Permit User Sessions.
Nov 07 07:51:07 home systemd[1]: run-user-1000.mount: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Unmounted /run/user/1000.
Nov 07 07:51:07 home systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Nov 07 07:51:07 home systemd[1]: Stopped User Runtime Directory /run/user/1000.
Nov 07 07:51:07 home systemd[1]: systemd-logind.service: Deactivated successfully.
Nov 07 07:51:08 home systemd[1]: Stopped User Login Management.
Nov 07 07:51:08 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.2" (uid=0 pid=1 comm="/sbin/init") interface="org.freedesktop.DBus" member="RemoveMatch" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:08 home systemd[1]: Removed slice User Slice of UID 1000.
Nov 07 07:51:08 home systemd[1]: user-1000.slice: Consumed 40.974s CPU time.
Nov 07 07:51:08 home systemd[1]: Stopped target Network.
Nov 07 07:51:08 home systemd[1]: Stopped target Remote File Systems.
Nov 07 07:51:08 home systemd[1]: Stopping Network Manager...
Nov 07 07:51:08 home NetworkManager[1187]: <info> [1699332668.0376] caught SIGTERM, shutting down normally.
Nov 07 07:51:08 home NetworkManager[1187]: <info> [1699332668.0388] manager: NetworkManager state is now CONNECTED_SITE
Nov 07 07:51:08 home dbus-daemon[1083]: [system] Would reject message, 4 matched rules; type="method_call", sender=":1.4" (uid=0 pid=1187 comm="/usr/bin/NetworkManager --no-daemon") interface="org.freedesktop.nm_dispatcher" member="Action" error name="(unset)" requested_reply="0" destination="org.freedesktop.nm_dispatcher" (bus)
Nov 07 07:51:08 home dbus-daemon[1083]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=1187 comm="/usr/bin/NetworkManager --no-daemon")
Nov 07 07:51:08 home NetworkManager[1187]: <info> [1699332668.0392] device (wlp2s0f0u3): state change: unavailable -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Nov 07 07:51:08 home dbus-daemon[1083]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Nov 07 07:51:08 home NetworkManager[1187]: <info> [1699332668.0577] device (wlp2s0f0u3): set-hw-addr: reset MAC address to 14:EB:B6:26:FA:BB (unmanage)
Nov 07 07:51:08 home NetworkManager[1187]: <info> [1699332668.1011] exiting (success)
Nov 07 07:51:08 home dbus-daemon[1083]: [system] Would reject message, 3 matched rules; type="method_call", sender=":1.4" (uid=0 pid=1187 comm="/usr/bin/NetworkManager --no-daemon") interface="org.freedesktop.DBus" member="RemoveMatch" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
Nov 07 07:51:08 home systemd[1]: NetworkManager.service: Deactivated successfully.
Nov 07 07:51:08 home systemd[1]: Stopped Network Manager.
Nov 07 07:51:08 home systemd[1]: Stopping D-Bus System Message Bus...
Nov 07 07:51:08 home systemd[1]: dbus.service: Deactivated successfully.
Nov 07 07:51:08 home systemd[1]: Stopped D-Bus System Message Bus.
Nov 07 07:51:09 home snapd[1087]: overlord.go:515: Released state lock file
Nov 07 07:51:09 home systemd[1]: snapd.service: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Stopped Snap Daemon.
Nov 07 07:51:09 home systemd[1]: Stopped target Basic System.
Nov 07 07:51:09 home systemd[1]: Stopped target Path Units.
Nov 07 07:51:09 home systemd[1]: cups.path: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Stopped CUPS Scheduler.
Nov 07 07:51:09 home systemd[1]: Stopped target Slice Units.
Nov 07 07:51:09 home systemd[1]: Removed slice User and Session Slice.
Nov 07 07:51:09 home systemd[1]: user.slice: Consumed 40.974s CPU time.
Nov 07 07:51:09 home systemd[1]: Stopped target Socket Units.
Nov 07 07:51:09 home systemd[1]: Stopped target System Time Set.
Nov 07 07:51:09 home systemd[1]: avahi-daemon.socket: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Nov 07 07:51:09 home systemd[1]: cups.socket: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Closed CUPS Scheduler.
Nov 07 07:51:09 home systemd[1]: dbus.socket: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Closed D-Bus System Message Bus Socket.
Nov 07 07:51:09 home systemd[1]: snapd.socket: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Closed Socket activation for snappy daemon.
Nov 07 07:51:09 home systemd[1]: Stopped target System Initialization.
Nov 07 07:51:09 home systemd[1]: Stopped target Local Encrypted Volumes.
Nov 07 07:51:09 home systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Nov 07 07:51:09 home systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Nov 07 07:51:09 home systemd[1]: Stopped target Local Integrity Protected Volumes.
Nov 07 07:51:09 home systemd[1]: Stopped target Local Verity Protected Volumes.
Nov 07 07:51:09 home systemd[1]: Stopping Set Up Additional Binary Formats...
Nov 07 07:51:09 home systemd[1]: systemd-sysctl.service: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Stopped Apply Kernel Variables.
Nov 07 07:51:09 home systemd[1]: systemd-coredump.socket: Deactivated successfully.
Nov 07 07:51:09 home systemd[1]: Closed Process Core Dump Socket.
Nov 07 07:51:09 home systemd[1]: systemd-modules-load.service: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Stopped Load Kernel Modules.
Nov 07 07:51:10 home systemd[1]: systemd-modules-load.service: Consumed 1.782s CPU time.
Nov 07 07:51:10 home systemd[1]: Stopping Network Time Synchronization...
Nov 07 07:51:10 home systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Nov 07 07:51:10 home systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Stopped Network Time Synchronization.
Nov 07 07:51:10 home systemd[1]: systemd-binfmt.service: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Stopped Set Up Additional Binary Formats.
Nov 07 07:51:10 home systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Nov 07 07:51:10 home systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Nov 07 07:51:10 home systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Stopped Create Volatile Files and Directories.
Nov 07 07:51:10 home systemd[1]: Stopped target Local File Systems.
Nov 07 07:51:10 home systemd[1]: Stopped target Mounted snaps.
Nov 07 07:51:10 home systemd[1]: Unmounting /boot/efi...
Nov 07 07:51:10 home systemd[1]: Unmounting /gen3-ssd...
Nov 07 07:51:10 home systemd[1]: Unmounting /home/yar85/.cache/google-chrome/Default...
Nov 07 07:51:10 home systemd[1]: Unmounting /sata-ssd...
Nov 07 07:51:10 home systemd[1]: Unmounting /sata-ssd2...
Nov 07 07:51:10 home systemd[1]: Unmounting Temporary Directory /tmp...
Nov 07 07:51:10 home kernel: EXT4-fs (sda1): unmounting filesystem c9139686-4d28-43ad-b385-31bd065e584f.
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for android-studio, revision 127...
Nov 07 07:51:10 home ntfs-3g[990]: Unmounting /dev/sdb3 (700 GB win10)
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for android-studio, revision 128...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for bare, revision 5...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for code, revision 144...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for code, revision 145...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for core, revision 16091...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for core, revision 16202...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for core18, revision 2790...
Nov 07 07:51:10 home kernel: EXT4-fs (nvme1n1p3): unmounting filesystem 3fbbd346-be2d-489b-902e-cf7e8de995fb.
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for core18, revision 2796...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for core20, revision 1974...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for core20, revision 2015...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for core22, revision 858...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for core22, revision 864...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for espanso, revision 129...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for flutter, revision 130...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for flutter, revision 141...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for gifcurry, revision 9...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for gnome-3-28-1804, revision 194...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for gnome-3-28-1804, revision 198...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for gnome-3-34-1804, revision 90...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for gnome-3-34-1804, revision 93...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for gnome-3-38-2004, revision 140...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for gnome-3-38-2004, revision 143...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for gtk-common-themes, revision 1534...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for gtk-common-themes, revision 1535...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for insomnia, revision 231...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for insomnia, revision 233...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for snapd, revision 20092...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for snapd, revision 20290...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for spotify, revision 68...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for spotify, revision 70...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for stress-ng, revision 7666...
Nov 07 07:51:10 home systemd[1]: Unmounting Mount unit for stress-ng, revision 7671...
Nov 07 07:51:10 home systemd[1]: boot-efi.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted /boot/efi.
Nov 07 07:51:10 home systemd[1]: gen3\x2dssd.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted /gen3-ssd.
Nov 07 07:51:10 home systemd[1]: home-yar85-.cache-google\x2dchrome-Default.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted /home/yar85/.cache/google-chrome/Default.
Nov 07 07:51:10 home systemd[1]: sata\x2dssd.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted /sata-ssd.
Nov 07 07:51:10 home systemd[1]: sata\x2dssd2.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted /sata-ssd2.
Nov 07 07:51:10 home systemd[1]: tmp.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Temporary Directory /tmp.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-android\x2dstudio-127.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for android-studio, revision 127.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-android\x2dstudio-128.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for android-studio, revision 128.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-bare-5.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for bare, revision 5.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-code-144.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for code, revision 144.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-code-145.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for code, revision 145.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-core-16091.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for core, revision 16091.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-core-16202.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for core, revision 16202.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-core18-2790.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for core18, revision 2790.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-core18-2796.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for core18, revision 2796.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-core20-1974.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for core20, revision 1974.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-core20-2015.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for core20, revision 2015.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-core22-858.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for core22, revision 858.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-core22-864.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for core22, revision 864.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-espanso-129.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for espanso, revision 129.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-flutter-130.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for flutter, revision 130.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-flutter-141.mount: Deactivated successfully.
Nov 07 07:51:10 home systemd[1]: Unmounted Mount unit for flutter, revision 141.
Nov 07 07:51:10 home systemd[1]: var-lib-snapd-snap-gifcurry-9.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for gifcurry, revision 9.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-194.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for gnome-3-28-1804, revision 194.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-198.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for gnome-3-28-1804, revision 198.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-gnome\x2d3\x2d34\x2d1804-90.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for gnome-3-34-1804, revision 90.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-gnome\x2d3\x2d34\x2d1804-93.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for gnome-3-34-1804, revision 93.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-gnome\x2d3\x2d38\x2d2004-140.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for gnome-3-38-2004, revision 140.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-gnome\x2d3\x2d38\x2d2004-143.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for gnome-3-38-2004, revision 143.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1534.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for gtk-common-themes, revision 1534.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1535.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for gtk-common-themes, revision 1535.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-insomnia-231.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for insomnia, revision 231.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-insomnia-233.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for insomnia, revision 233.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-snapd-20092.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for snapd, revision 20092.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-snapd-20290.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for snapd, revision 20290.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-spotify-68.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for spotify, revision 68.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-spotify-70.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for spotify, revision 70.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-stress\x2dng-7666.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for stress-ng, revision 7666.
Nov 07 07:51:11 home systemd[1]: var-lib-snapd-snap-stress\x2dng-7671.mount: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Unmounted Mount unit for stress-ng, revision 7671.
Nov 07 07:51:11 home systemd[1]: Stopped target Mounting snaps.
Nov 07 07:51:11 home systemd[1]: Stopped target Swaps.
Nov 07 07:51:11 home systemd[1]: Deactivating swap /dev/disk/by-diskseq/3-part2...
Nov 07 07:51:11 home systemd[1]: systemd-fsck@dev-disk-by\x2duuid-3fbbd346\x2dbe2d\x2d489b\x2d902e\x2dcf7e8de995fb.service: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Stopped File System Check on /dev/disk/by-uuid/3fbbd346-be2d-489b-902e-cf7e8de995fb.
Nov 07 07:51:11 home systemd[1]: systemd-fsck@dev-disk-by\x2duuid-49AA\x2d209B.service: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Stopped File System Check on /dev/disk/by-uuid/49AA-209B.
Nov 07 07:51:11 home systemd[1]: systemd-fsck@dev-disk-by\x2duuid-c9139686\x2d4d28\x2d43ad\x2db385\x2d31bd065e584f.service: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Stopped File System Check on /dev/disk/by-uuid/c9139686-4d28-43ad-b385-31bd065e584f.
Nov 07 07:51:11 home systemd[1]: Removed slice Slice /system/systemd-fsck.
Nov 07 07:51:11 home systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2dnvme\x2d1\x2dpart2.swap: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:01:00.0-nvme-1-part2.
Nov 07 07:51:11 home systemd[1]: dev-disk-by\x2did-nvme\x2dSamsung_SSD_980_PRO_500GB_S5GYNX0RC15278D\x2dpart2.swap: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Deactivated swap /dev/disk/by-id/nvme-Samsung_SSD_980_PRO_500GB_S5GYNX0RC15278D-part2.
Nov 07 07:51:11 home systemd[1]: dev-disk-by\x2did-nvme\x2dSamsung_SSD_980_PRO_500GB_S5GYNX0RC15278D_1\x2dpart2.swap: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Deactivated swap /dev/disk/by-id/nvme-Samsung_SSD_980_PRO_500GB_S5GYNX0RC15278D_1-part2.
Nov 07 07:51:11 home systemd[1]: dev-disk-by\x2did-nvme\x2deui.002538bc11b947a7\x2dpart2.swap: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Deactivated swap /dev/disk/by-id/nvme-eui.002538bc11b947a7-part2.
Nov 07 07:51:11 home systemd[1]: dev-disk-by\x2ddiskseq-3\x2dpart2.swap: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Deactivated swap /dev/disk/by-diskseq/3-part2.
Nov 07 07:51:11 home systemd[1]: dev-disk-by\x2dpartuuid-0065911e\x2dec5e\x2d9244\x2d884f\x2d04ba34084146.swap: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Deactivated swap /dev/disk/by-partuuid/0065911e-ec5e-9244-884f-04ba34084146.
Nov 07 07:51:11 home systemd[1]: dev-nvme0n1p2.swap: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Deactivated swap /dev/nvme0n1p2.
Nov 07 07:51:11 home systemd[1]: dev-disk-by\x2duuid-2ed17d7a\x2d5df9\x2d40b9\x2d90a0\x2d41a168065073.swap: Deactivated successfully.
Nov 07 07:51:11 home systemd[1]: Deactivated swap /dev/disk/by-uuid/2ed17d7a-5df9-40b9-90a0-41a168065073.
Nov 07 07:51:18 home systemd[1]: hdd.mount: Deactivated successfully.
Nov 07 07:51:18 home systemd[1]: Unmounted /hdd.
Nov 07 07:51:18 home systemd[1]: Stopped target Preparation for Local File Systems.
Nov 07 07:51:18 home systemd[1]: Reached target Unmount All Filesystems.
Nov 07 07:51:18 home systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Nov 07 07:51:18 home systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Nov 07 07:51:18 home systemd[1]: Stopped Remount Root and Kernel File Systems.
Nov 07 07:51:18 home systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Nov 07 07:51:18 home systemd[1]: Stopped Create Static Device Nodes in /dev.
Nov 07 07:51:18 home systemd[1]: systemd-tmpfiles-setup-dev-early.service: Deactivated successfully.
Nov 07 07:51:19 home systemd[1]: Stopped Create Static Device Nodes in /dev gracefully.
Nov 07 07:51:19 home lvm[2833]: 3 logical volume(s) in volume group "vg-old" unmonitored
Nov 07 07:51:19 home lvm[2833]: 3 logical volume(s) in volume group "vg-data" unmonitored
Nov 07 07:51:19 home systemd[1]: lvm2-monitor.service: Deactivated successfully.
Nov 07 07:51:19 home systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Nov 07 07:51:19 home systemd[1]: Reached target System Shutdown.
Nov 07 07:51:19 home systemd[1]: Reached target Late Shutdown Services.
Nov 07 07:51:19 home systemd[1]: systemd-poweroff.service: Deactivated successfully.
Nov 07 07:51:19 home systemd[1]: Finished System Power Off.
Nov 07 07:51:19 home systemd[1]: Reached target System Power Off.
Nov 07 07:51:19 home systemd[1]: Shutting down.
Nov 07 07:51:19 home systemd-shutdown[1]: Syncing filesystems and block devices.
Nov 07 07:51:19 home systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Nov 07 07:51:19 home systemd-journald[537]: Received SIGTERM from PID 1 (systemd-shutdow).
Nov 07 07:51:19 home systemd-journald[537]: Journal stopped
