I am trying to install a dkms module that tainst the kernel. I have SecureBoot disabled. I see that there is a file related to that, /etc/dkms/sign_helper.sh, that points to non-existing /root/mok.priv and /root/mok.der files. What should I do? The only solution I found relies on enabling SecureBoot, but if I enable it manjaro doesn’t boot.
Have you verified that the module is indeed not loaded?
That message is just a warning/informational message, as far as I know.
The module will still be loaded and should work.
Is the module build using a PKGBUILD or did you compile it by hand?
Have you checked the build instructions for the module?
It could contain instructions on how to create a self signed certificate which seems to be needed for the kernel to accept the module.
As you are using dkms - did you install the headers for kernel you are building for? Remember that PKGBUILDs from AUR is created for Arch - and as Arch uses a different kernel naming - you cannot rely on the PKGBUILD dependency array.
