English text see below.
Guten Morgen.
Unter Raspi OS kann ich den Pi4, 4GB, mit folgenden Einstellungen betreiben:
arm_freq=2150
overvoltage=6
GPU_memory=512
Wie kann ich das unter Manjaro ARM, 64bit, erreichen?
Bin für jeden Tip dankbar.
Grüße
Karl
Good morning.
Under Raspi OS I can run the Pi4, 4GB, with the following settings:
arm_freq=2150
overvoltage=6
GPU_memory=512
How can I achieve this under Manjaro ARM, 64bit?
Am grateful for any tip.
Greetings
Karl
0n0w1c
26 December 2020 03:50
2
Edit /boot/config.txt
#firmware
gpu_mem=512
#overclocking
over_voltage=6
arm_freq=2150
gpu_freq=750
@0n0w1c
Thank you for your response.
But which config.txt must be changed?
There are two of them.
Regards
Karl
0n0w1c
26 December 2020 18:44
4
I know of only /boot/config.txt
Maybe you are thinking of /boot/cmdline.txt? This is not the file to edit.
I also OC on manjaro on pi4. It’s /boot/config.txt for me. Which ever one is in the base of the FAT firmware partition with the overlay directory and all the elf boot files.
