I have created GitHub actions to create rootfs for Android Termux. It will be used as proot distro.
I created it to use desktop version of app in Android. It sometimes lag, it is used in proot so it will be lag. It works fine by the way. But my question is, will it be more optimized? If can be optimized then how to do it ?
This is Docker file for creating rootfs.
## Create rootfs from scratch
FROM scratch
ADD . /
RUN uname -a
## Update and install the base and sudo packages
## RUN pacman-mirrors -gf
RUN pacman-mirrors --country Germany,France,Austria \
&& pacman-key --init \
&& pacman-key --populate
## Fix common directory permissions
RUN chmod -cf 775 /var/games 2>/dev/null \
&& chmod -cf 1777 /tmp /var/spool/mail /var/tmp 2>/dev/null \
&& chmod -cf 2755 /var/log/journal 2>/dev/null
RUN pacman -Syyuu --noconfirm base sudo manjaro-release
## Install DE and additional packages
RUN pacman -Sy --noconfirm --needed xfce4 \
## Minimal packages
nano zswap-arm openssh wget \
## File systems access
mpv \
## Sound, video and bluetooth
pavucontrol pulseaudio-alsa \
## Package Manager
pamac-gtk \
## Fonts
ttf-bitstream-vera noto-fonts wqy-microhei \
## Applications
manjaro-settings-manager \
## Themes
qt5ct kvantum-qt5 kvantum-theme-matchama matcha-gtk-theme manjaro-arm-wallpapers papirus-maia-icon-theme xcursor-breeze
## Install TigerVNC 1.10.1
RUN pacman -S tar wget sed --noconfirm \
&& pacman -U /tigervnc-1.10.1-1-aarch64.pkg.tar.xz --noconfirm \
&& tar xf /usr/lib/a.tar.xz -C /usr/lib \
&& sed -i '27i IgnorePkg = tigervnc' /etc/pacman.conf \
&& rm /tigervnc-1.10.1-1-aarch64.pkg.tar.xz
## Setup TigerVNC
RUN mkdir -p /etc/skel/.vnc \
&& echo "#!/bin/sh" >> /etc/skel/.vnc/xstartup \
&& echo "unset SESSION_MANAGER" >> /etc/skel/.vnc/xstartup \
&& echo "export DISPLAY=:1" >> /etc/skel/.vnc/xstartup \
&& echo "export PULSE_SERVER=127.0.0.1" >> /etc/skel/.vnc/xstartup \
&& echo "pulseaudio --start" >> /etc/skel/.vnc/xstartup \
&& echo "[[ -r \${HOME}/.Xresources ]] && xrdb \${HOME}/.Xresources" >> /etc/skel/.vnc/xstartup \
&& echo "exec dbus-launch startxfce4" >> /etc/skel/.vnc/xstartup \
&& chmod -cf +x /etc/skel/.vnc/xstartup \
&& echo "Desktop=manjaro" >> /etc/skel/.vnc/config \
&& echo "Geometry=1024x768" >> /etc/skel/.vnc/config \
&& echo "SecurityTypes=VncAuth,TLSVnc" >> /etc/skel/.vnc/config \
&& echo "Localhost" >> /etc/skel/.vnc/config \
&& chmod +x /usr/local/bin/vncserver-start \
&& chmod +x /usr/local/bin/vncserver-stop
## Install Packages required by Anki
RUN pacman -Sy --noconfirm --needed python-pyqt5 python-pyqtwebengine python-pip
## Install Anki
RUN pip install https://github.com/infinyte7/anki-arm64/releases/download/v0.0.1-archarm/anki-2.1.47-cp38-abi3-manylinux2014_aarch64.whl
RUN pip install https://github.com/infinyte7/anki-arm64/releases/download/v0.0.1-archarm/aqt-2.1.47-py3-none-any.whl
RUN mv anki.desktop /usr/share/applications/anki.desktop \
&& mv anki.png /usr/share/pixmaps/anki.png
RUN paccache -rk0
Link to project manjaro-fs-arm64
