I recently installed Manjaro XFCE on my older laptop (it’s about 6 years old, with 4GB RAM and an Intel i3 processor). The installation went smoothly, but I’ve noticed that the system can feel a bit sluggish at times, especially when running multiple applications.
I am wondering if there are any tweaks or settings that I could apply to optimize performance. I’ve already disabled some startup applications and set swappiness to 10, but I’m not sure if there’s more I could do.
I have not found any solution. Could anyone guide me about this? Would love to hear any advice from the community on improving speed and responsiveness on older hardware. Any particular tools or settings you recommend?
But I have 16GB of ram. I’d suggest enabling enough SWAP space, about 200% (8GB) of your current RAM, and leaving the swappiness at the default, which I think is 60.
Mabox linux is kind of manjato fork but instead of full desktop environment only with window manager. That would sava about a gig of ram, which is something you will feel if you only have 4.
I agree, though, more RAM might be generally beneficial.
Upgrading the disk to perhaps an SSD, or even NVMe storage, might also enhance performance overall.
Note that these comments are without the benefit of knowing anything about your system. As already mentioned by @cscs and @Kobold, system information will be helpful to others; please post some.
