Is it possible to open the system settings from the terminal with a command?
systemsettings5
Your profile says you’re using GNOME, so it would be gnome-control-center.
bmenu
Sure, if he was using KDE. He’s not.
That has nothing to do with the original query.
Tip: [HowTo] Post command output and file content as formatted text
