Hi there !!
I am facing this issue of opening ranger in Terminator
I changed some configuration of ~/.local/share/applications/ranger.desktop & /usr/share/applications/ranger.desktop
to set terminal to terminator… nothing worked
Ranger is still opening in urxvt
I have no further information on how to open this thing in terminator
and my default i3-sensible-terminal is set to terminator
but lunching terminal opens up urxvt
Guys off topic I deleted the entire home folder while playing with ranger
Any suggestion in recovering it ?
Yeah Thanks for that…I actually can do that
but I open up ranger via Dmenu…
I guess I have to change something of dmenu but don’t know what
I have one more question i.e
like first time you open up a program from dmenu you have option to choose from
Background Terminal and one more option
Can you tell me where can I go and change that ?
Easy fix here would be to edit /usr/share/applications/ranger.desktop and change the Exec line. Save and exit and now dmenu should open it in terminator.
#from this
Exec=ranger
#to this
Exec=terminator -x ranger
Navigate to the directory ~/.config/dmenu-recent/ and delete the lines that are referring to the program(s) either from the background or the terminal file in that directory.
Next time you launch dmenu you will be prompted to use background or terminal for the specific program.
Hi There !!
I think I found the solution
you just have to change the ~/.dmenurc or dmenu configuration file located else where
In my case it was in home folder (~/)
Replace terminal -e with terminator -x in the configuation file of dmenu
However
But I wanted to know how to change the default terminal to terminator instead of urxvtc
Hi
Now another issue
I cannot find urxvtc package to remove… can you tell me what the package name is ?
because it doesn’t give me any info about the package while I do
