I am planning to use my laptop for audio recording but, for some reason, the speed of the fan seems to be constantly on full throttle, even when the system is idle. I have installed cpufreq to manage power output and can say I am satisfied with the result, but I’d like to manually manage the system fan and set it to minimum.
Is this possible? if yes, how?
thanks a lot for any input
