How to make the GNOME Shell clock appear with a larger font?
What would be a good GNOME Shell theme to use for this?
Otherwise, can someone guide me to change some CSS file that does this?
Thanks.
For years Gnome has used compiled resourses - so there is no css to change.
You will have to extract the resources - then change the source - and recompile it.
This is a highly error prone process - I played around with the gdm lockscreen long time ago - I don’t recommend messing with it - there is a fair chance of getting weird issues with the shell.
I haven’t used Gnome for a long time - I had too many issues - so I switched to a simpler setup.
Thank you for the answer!
If you don’t want to mess with your system, you can use a VM for testing.
Download and test themes, take some notes, pick your favourites.
You can find themes notably:
  • into Manjaro repositories
  • from AUR
  • at pling.com
