How to make systemd ignore a mountpoint during shutdown process?
I mounted an overlayfs mounted on /mnt/overlay. I noticed that systemd unmount mountpoints indiscriminately upon shutdown including /mnt/overlay. How to make /mnt/overlay to be ignore by systemd. I will just want to unmount it when final target is reached. Also how to log all the systemd shutdown process?
Hi @mistfire,
Add and After= directive to the [Unit] section of the mount unit with the target you want it to be after.
See:
Hope this helps!
Edit:
This might also help:
https://serverfault.com/a/1058947
…to get the full list of reverse dependencies for shutdown-target as asked in the original post, was:
systemctl list-dependencies --after shutdown.target
