How to make Proxy config in Manjaro XFCE environment?
The system I am using is XFCE, apparantly this version of manjaro does not come with the proxy settings that we get to see in the KDE or Ubuntus. The etc/profile is for command line, I have read
https://forum.manjaro.org/t/how-can-i-do-wide-system-proxy-xfce/29976 thoroughly,
it inspires me some how, I don’t know whether it is possible or not to use the PAC like the typical ubuntu proxy.
I use a clash as the tunnel to connect to network, so that means the proxy is offering me a port on the local machine, like http → 7890, socks5 → 7891.
From the experience of the past using Ubuntu, I just need to take the proxy configuration and type the 7890 or 7891, then it’s all done, I don’t know how to do that in XFCE
Right click on the Network icon in the Panel > Edit connections…
In the opened window click on the name of connection you have, then at the bottom click on the Settings gear icon
Go to Proxy tab and do your thing :wink:
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
