Thanks for any help. Beginner here so please be patient.
I was updating some packages and after a restart Manjaro started booting with an error message reading:
[FAILED] failed to start CUPS Scheduler
[FAILED] failed to start accounts service
After some time Manjaro loads into my desktop but mouse and keyboard are disabled.
Notes:
– Mouse and Keyboard work in BIOS and GRUB menu
– After reading some support entries I tried by pressing Alt + F2 to login manually and run some pacman database sync. The issue is that while I am typing the commands linux loads the desktop.
– When getting stuck in the i3 desktop I can see the NVIDIA text at the bottom.
– I have tried loading with these kernels: 6.1.33 / 5.15.12 / 5.10.174
Do you mean that when you reach the login screen for manjaro, you press alt+f2 and after logging into the new tty with your username and pass, the desktop suddenly loads?
My user logs in automatically without arriving to the login/pass screen. In this instance it arrives with keyboard and mouse locked. However, after the error shows up when booting I press Alt + F2, I get a console login/pass prompt and then I have access to the console ( keyboard works here) . Then after a few seconds it launches automatically the desktop,
This is when being a beginner kicks. Typing on my console lasts very little so I can’t type all that.
If only I could type one line to stop it to load the desktop that’ll be a good step.
It’s a Vostro 7500, right? Is your printer plugged in to a USB port? Do your USB ports fail to work with other equipment too, eg a flash drives? If that is the case check in your Bios that “Enable external USB ports” is not set to ‘disabled’ (If it is, mouse and keyboard will work in bios but stop working at desktop.).
The keyboard is working when launching the console before going to the desktop and getting unresponsive. I even plugged a wireless keyboard and it works in the console and both keyboard and mouse work in the bios.
OK I’m going to take a stab at his. The keyboard and mouse working in bios has nothing to with Manjaro because it hasn’t even loaded yet. Are you using a wireless mouse and keyboard. If so don’t. Now the brute force solution is to download a new ISO and reinstall. Now tell us what Nvidia drivers you use and tell us what if anything is broken.
