There is the the Notification Plugin for the XFCE Panel. It will show all notification, current and old. But you need to log all your notifications, not only during “Do not disturb”.
Thank you for the explanation. Can I install the GNOME notification menu on xfce?
No idea my man, sorrry!
You are free to do whatever you like, but if this gain of function experiment does not work it is your responsibilty
thank you bro
Thank you bro for the information, I want to ask another question, What do you recommend me to use? vpn file that works well and permanently.i use https://www.vpngate.net/en/ But I can’t find the file easily, and if I do, it crashes after a while Is there a good program to recommend or is there a way to permanently change the system IP
VPN Gate is based on SoftEther VPN, a multi-protocol VPN server
