How to make nano the default editor on the system,also crontab.
I use MATE desktop. I use Bash
Hi @Snubbi,
I wrote this for someone today. Don’t know if it’ll work, but I’m guessing it will:
Note:
In your case you’d need to replace $BROWSER with $EDITOR.
My $EDITOR if the following:
$ echo $EDITOR
/usr/bin/nano
Hope this helps!
I found this page https://linuxize.com/post/how-to-use-nano-text-editor/ is not the right way to do it?
Add to /etc/environment FILE (for root)
or/and FOR USER to ~/.bash_profile
export EDITOR="/usr/bin/nano"
export VISUAL=$EDITOR
For edit /etc/sudoers with nano you need once edit sudoers config:
sudo -i
export EDITOR=nano
visudo
add at end of file:
## Set nano as default editor
Defaults env_reset
Defaults editor=/usr/bin/nano, !env_editor
Save changes in files.
It would be better to leave sudoers untouched and make a config file in /etc/sudoers.d/ name it 20-whatever and add the changes there.
https://wiki.archlinux.org/index.php/Sudo#Configure_sudo_using_drop-in_files_in_/etc/sudoers.d
