I am using Manjaro XFCE, but I have the Qt app gwenview installed. When I browse my phone through KDE connect, it opens the files with gwenview.
How to make KDE connect browse files in Thunar?
Hi, @archisman
I wonder whether I could recommend to read the following links:
‘https://github.com/b4j4/indicator-kdeconnect’
‘KDE Connect & GS Connect Issue | Linux.org’
Hope this help, regards
xdg-mime default Thunar.desktop inode/directory
you can also search for “inode/directory” in default applications>>>other>>>and set with thunar.
Somehow the command did not do the job, but it worked after setting it in GUI.
