Matia
26 December 2022 14:30
1
I’m using a laptop with hybrid AMD/NVIDIA (GeForce RTX 360) graphics and I’ve selected the proprietary drivers and read the Configure Graphics Card section on the Manjaro wiki but I can’t get it work when I try opening DaVinci Resolve I get “Unsupported GPU process mode” which indicates it doesn’t work.
In Hardware Configuration it shows video-hybrid-amd-nvidia-prime
together with video-linux
as installed.
When I run glxinfo | grep OpenGL
I get this which is interesting because I assume it would use the NVIDIA drivers but I don’t know how it works.
OpenGL vendor string: AMD
OpenGL renderer string: AMD Radeon Graphics (renoir, LLVM 14.0.6, DRM 3.42, 5.15.85-1-MANJARO)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 22.3.1
OpenGL core profile shading language version string: 4.60
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 22.3.1
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 22.3.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
I’ve read that Wayland might cause problem but echo $XDG_SESSION_TYPE
returns x11
brahma
26 December 2022 16:57
2
you can use your nvidia with the prime-run
command, for example:
prime-run program_name
and provide full system info:
inxi -Fazv7
Matia
26 December 2022 17:56
3
I forgot to say I’ve ran it using prime-run
as the wiki suggested.
prime-run /opt/resolve/bin/resolve
Here’s the system info.
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=0cce88bf-33b0-496d-ac9f-ebf3628f7c12 rw quiet splash apparmor=1
security=apparmor resume=UUID=97ad0e8e-91d1-4347-bc55-5ebd80daf19c
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: LENOVO product: 82K2 v: IdeaPad Gaming 3 15ACH6
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ACH6
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
UEFI: LENOVO v: H3CN32WW(V2.02) date: 02/23/2022
ID-1: BAT1 charge: 59.8 Wh (96.5%) condition: 62.0/60.0 Wh (103.3%)
volts: 17.2 min: 15.4 model: 0x43 0x65 0x6C 0x78 0x70 0x 0x4C 0x32 0x30
0x43 0x34 0x50 0x6000 type: Li-ion serial: <filter> status: discharging
cycles: 5
RAM: total: 13.51 GiB used: 2.57 GiB (19.1%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2213 high: 3549 min/max: 1200/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1393 2: 1397
3: 3106 4: 2714 5: 2896 6: 3199 7: 1916 8: 1915 9: 2315 10: 2395 11: 1197
12: 1197 13: 1197 14: 1598 15: 3549 16: 3424 bogomips: 102241
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0302
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 42.0 C
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x06d8 built: 2021
res: 1920x1080 hz: 165 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.42 5.15.85-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 6 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 28.28 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA1T0QFD
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 0013P6LN temp: 29.9 C scheme: GPT
ID-1: / raw-size: 938.71 GiB size: 922.9 GiB (98.32%) used: 28.28 GiB (3.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0cce88bf-33b0-496d-ac9f-ebf3628f7c12
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: BF84-7487
ID-1: swap-1 type: partition size: 14.86 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 97ad0e8e-91d1-4347-bc55-5ebd80daf19c
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: IMC Networks Integrated Camera type: Video
Device-2: 1-4:3 info: Foxconn / Hon Hai Wireless_Device type: Bluetooth
driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Integrated Express ITE Device(8176) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c966 class-ID: 0301
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.2 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 356 Uptime: 2d 5h 41m wakeups: 7 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1556 pm: pacman pkgs: 1546 libs: 448 tools: gnome-software,pamac
pm: flatpak pkgs: 0 pm: snap pkgs: 10 Shell: Zsh v: 5.9 running-in: kgx
inxi: 3.3.24
Olli
26 December 2022 17:59
4
what’s the output of
glxinfo | grep server
and the output of
prime-run glxinfo | grep server
Matia
26 December 2022 18:04
5
The ouput using glxinfo
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
The output using prime-run
server glx vendor string: NVIDIA Corporation
Olli
26 December 2022 18:06
6
what happens if you start DaVinci from console with prime ?
prime-run DaVinciResolvProgramName
Matia
26 December 2022 18:14
7
How do I find out the name?
I don’t think there is one because I tried it before and couldn’t find the answer.
I tried out GIMP and Blender which seems to work but not sure how to confirm it works other than it doesn’t throw an error.
brahma
26 December 2022 18:23
8
you can check with nvidia-smi
which programs are using nvidia… so run blender/gimp via prime-run, and then check with nvidia-smi
Matia
26 December 2022 18:30
9
Thank you!
It works — I did nothing different other than try out GIMP and Blender with prime-run
and even tried sudo
to start DaVinci Resolve which didn’t work but might have done something.
I can even open DaVinci Resolve like a regular program and it just works.
Should I still prepend things I want to run on the GPU with prime-run
or does it just know?
Olli
26 December 2022 18:34
10
You must ! Otherwise you have to use optimus-manager to preset the gpu
system
Closed
29 December 2022 08:38
12
