my spacebar is sticky and i want my left alt key act as my spacebar
- Turn off your machine
- Remove the battery
- Apply 3 drops of 95 volume% (190°proof) alcohol to the front of the space bar
(left corner, right corner, middle) - Wait 3 seconds
- Blow out the alcohol with a can of compressed air for 6 seconds
- repeat until the spacebar is unstuck
- leave the machine to dry for 1 hour at room T° (21°)
50% vodka will do the trick too, but use 12 seconds for the blow-out as it contains more water that takes longer to evaporate
