Hello,
i d like to give one of the developer snapshot a try but i don
t know, how to get a bootable iso as the download isos have such a strange name like iso z01…
what do i have to do to make a bootable usb stick with that iso?
Hello,
I download the latest from: Downloading File /kde-dev - Manjarolinux Community - OSDN
Checksum against the hash. Then burn the ISO using: Burn an ISO File - Manjaro
They are multi-part zips, download both .zip and .z01 then extract them with 7z x <name.zip>
no, not those…i mean the daily snapshots
ok…i` ll try. thanks
You only have to run the command on the .zip, 7z will automatically detect that it is multi-part.
Those files are partially 7zip archive.
You will need to download all the files - then put them together using p7zip.
Then you will have an ISO which you can write to USB using e.g. Mintstick from the repo.
Thank you very much for your help, that worked fine for me
