pacman -Qe
lists the explicitly installed packages on a system.
Is there a similar command for pamac
Since pamac
also searches AUR, can the pamac
command also be used to query explicitly installed packages from AUR?
Thank you.
pacman -Qe
Since pamac
Thank you.
No it’s not possible ATM.
There is a man page for pamac.
Although you can’t do exactly what you want, there is a column in pamac list -i
that shows where a package came from, like AUR. Redirect the output to a file and do a less on it. pamac list -m
, showed just the AUR installed packages on my system.
I’ve been looking at pacman -Qi
and grabbing the Name and Install Reason, which is either “Explicit” or “Installed as a dependecy for another package”, but there is nothing in the output indicating where (i.e, Repo).
Yes, it does.
But what I want to get is a text file listing of the package names.
Can the GUI output be stored as a text file as well: that would suit my purpose ideally.
Thanks.
What you can do in the GUI, you can do at the command line (see man pamac
# List installed packages
pamac list --installed
# Pipe output to awk and print the first field and redirect stdout to file
pamac list --installed | awk '{print $1}' > installed-files
Thanks, @stargazer
How do I find “explicitly installed” packages using pamac
on the command line?
It’s not yet possible but I will add it in a next release
This command can display packages installed through AUR
pamac list -i | grep AUR
and this command can save the list to a file
pamac list -i | grep AUR > aur_packages.txt
HHHhmmm. There’s pacman until pamac cli gets it.
I checked the code to see if it matched the man page. It does.
Here’s an interesting item. In the pamac source code directory there is an examples/python directory. There is an example, list_installed_pkgs_async.py, which when executed creates a list of all installed packages. You can replace the two calls (line 9 and line 19) which contain get_installed_pkgs_async to get_explicitly_installed_pkgs_async. The method can be seen in the src/database.vala file. I compared the output to pacman -Qe
and it’s the same.
If you list explicitly installed packages with pacman, it should also list AUR packages that are installed.
It does for me.
So pacman -Qe
will list all explicitly installed packages, no matter if it’s from repo, AUR or even self built. As long as it’s a package file that uses libalpm.
pacman -Qet
is probably a bit better than just -Qe
for people looking for explicitly installed packages as it produces a shorter list, which only prints
packages neither required nor optionally required by any currently installed package.
(from man pacman
But the more comprehensive result is definitely pacman -Qe
, particularly if you’re looking to free up as much storage space as possible. Just posting this option for people who didn’t want to peruse the whole manpage
Added in pamac 10.1.0
pamac list -e
Thank you.
I will try it out once it is rolled out. At present:
pamac --version
Pamac 10.0.5-1
