Hi all,
I know that after an upgrade I have to rebuild all AUR installed packages.
My question is how can I list all packages that were installed from AUR?
Hi all,
pacman -Qm
-m, --foreign
Restrict or filter output to packages that were not found in the sync database(s). Typically these are packages that were downloaded manually and installed with --upgrade.
I did find this:
https://bbs.archlinux.org/viewtopic.php?id=272335
which may be worth a read.
Thanks
What worked for me to list (alphabetically) AUR installed packages
First installed the utilities
pamac install expac pacutils
Then I used successufully exepac
[mirto@mostro ~]$ pacman -Qem | expac --timefmt="%F %T" "[%l] $(printf '\033[1;34m')%n$(printf '\033[0m') (%v)" - | sort -k3
[2025-02-15 19:20:21] bdinfo-git (r31.041c760-1)
[2024-06-05 12:52:58] gimp-extras (2.0.4-1)
[2024-10-09 09:24:53] lib32-libva-vdpau-driver (0.7.4-8)
[2024-07-17 09:56:10] libva-vdpau-driver (0.7.4-7)
[2025-02-16 18:39:55] makemkv (1.17.9-1)
[2024-05-13 13:17:26] manjaro-settings-manager-kcm (0.5.7-21)
[2024-07-17 09:56:15] reiserfsprogs (3.6.27-5)
[2024-05-13 13:14:16] spectre-meltdown-checker (0.46+23+g0f2edb1-1)
[mirto@mostro ~]$
and pacinfo
[mirto@mostro ~]$ pacman -Qqm | pacinfo | awk -F ": +" '/^Name:/{pkg=$2} /^Version:/{ver=$2} /^Install Date:/{print $2 " | \033[33m" pkg " \033[34m" ver "\033[0m"}' | sort -b -t"|" -k2
2025-02-15 19:20:21 | bdinfo-git r31.041c760-1
2024-06-05 12:52:58 | gimp-extras 2.0.4-1
2024-12-04 08:54:24 | ksanecore5 24.08.3-1
2024-10-09 09:24:53 | lib32-libva-vdpau-driver 0.7.4-8
2024-12-04 08:54:25 | libksane5 24.08.3-1
2024-07-17 09:56:10 | libva-vdpau-driver 0.7.4-7
2025-02-16 18:39:55 | makemkv 1.17.9-1
2024-05-13 13:17:26 | manjaro-settings-manager-kcm 0.5.7-21
2024-06-05 13:02:42 | opencollada 1:1.6.68-3
2024-07-17 09:56:15 | reiserfsprogs 3.6.27-5
2024-05-13 13:14:16 | spectre-meltdown-checker 0.46+23+g0f2edb1-1
2024-12-04 08:56:29 | v86d 0.1.10-13
2024-08-29 20:01:11 | xsane 0.999-7
[mirto@mostro ~]$
Thanks very much for posting the procedure you used! This is really helpful for other readers and is much appreciated!
Cheers! ![]()
You can also use:
pamac list -m
One advantage is that it tells you if a foreign package is specifically from the AUR. Blank ones are either no longer in the AUR, or were installed via another method such as git-clone & makepkg -srci (which is the case with maus, the helper I’ve been using for several years to update my system):
pamac list -m
amdgpu_top 0.10.3-1 AUR 18.2 MB
fclones-gui 0.2.0-2 AUR 3.9 MB
lyrics-in-terminal 1.7.0-1 AUR 155.3 kB
maus 1.2-1 70.5 kB
ocs-url 3.1.0-7 AUR 133.5 kB
python-desktop-notifier 6.0.0-2 AUR 286.1 kB
qarma-git r93.334236f-1 AUR 244.2 kB
qbittorrent-enhanced 5.0.3.10-1 AUR 13.4 MB
qimgv-qt6-kde-git v1.0.3.alpha.r134.gc913500-1 AUR 2.3 MB
solunar2-git 2.0c.r14.f30d862-1 AUR 198.4 kB
sunwait-git r34.151d834-1 AUR 39.2 kB
txt2html 2.5201-2 AUR 213.3 kB
vdhcoapp-bin 2.0.20-2 AUR 52.6 MB
videomerge 2.0.0-3 AUR 534.2 kB
wayclip 0.4.2-1 AUR 38.6 kB
Nice format - it’s also a nice idea to have a scheduled job to export pkglist.txt to a backup.
pacman -Qem | expac --timefmt="%F %T" "[%l] $(printf '\033[1;34m')%n$(printf '\033[0m') (%v)" - | sort -k3 > /mnt/T3/BackInTime/backintime/SteelLegend/ben/1/aur.txt
This prompted me to separate my pkglist into separate ‘system’ and ‘aur’ lists and put them right in the folder in Dolphin Places marked ‘backup’.
Pssst.
While it has been somehwat neglected since the move to 6.0 …
(dont use it for its main purpose on/for Plasma6 systems)
… transfuse does have this functionality and it could be called remotely;
$ bash <(curl -s https://gitlab.com/cscs/transfuse/-/raw/master/transfuse.sh) -p
Package lists created for 'native' and 'alien' packages and prefixed with 'NAME_20250219_1911'
$ cat NAME_20250219_1911_alien.txt
aseprite
beautysh
bindtointerface
browsh
geoclue_fake-git
gimp-devel
goodvibes
jamesdsp
jitsi-meet-desktop
klassy
labwc-tweaks-git
$ cat NAME_20250219_1911_native.txt
7zip
acpi
acpid
adobe-source-han-sans-cn-fonts
adobe-source-han-sans-jp-fonts
adobe-source-han-sans-kr-fonts
adobe-source-sans-fonts
alsa-firmware
alsa-utils
amd-ucode
arch-audit
ark
I was gonna say this may be useful on random other machines … but youd have to look up the command just as much as you would need to look up some expac string.
