How to label my partition, to show correct in dolphin?
Hello,
My new created gaming partition showed with the wrong name “196 GiB Internal Drive (sda3)” in dolphin.
As you see, i already named the label in KDE Partition Manager, but without success :frowning:
Optional Question, is ext4 or ext3 better for a gaming partition?
Edit: My “temp” Partition named correctly, and the only difference between this Partition was because my “temp” Partition was mounted in fstab and showed up in KDE Partition Manager under Mount point with /media/temp.
So my Gaming Partition are mounted in Dolphin with the difference under Mount Point /run/media/koboldx/Linux-games.
So can i mount my Partition with the correct name in dolphin or im forced to use Fstab?
Hmm i just found out that closing and re-open dolphin showed the correct label,
so its a temporary bug from dolphin, with unmounted partitions.
