Hello.
I installed the manjaro-pipewire thru the pamac and I want to know if I am currently using it right now or not. How can I know if where my sound coming from is pipewire, pulseAudio, Jack or ALSA?
Thank you guys (in advance and from my previous questions)!
hans
22 October 2021 12:45
2
first step, to see what is installed and running: inxi -A
Check system information
inxi -Ax | grep -E 'PulseAudio|PipeWire'
If you are using PulseAudio, sound servers should look like this:
Sound Server-4: PipeWire v: 0.3.38 running: no
For PipeWire it should look like this:
Sound Server-3: PipeWire v: 0.3.38 running: yes
cscs
22 October 2021 12:46
4
hello.
this is the result:
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] driver: snd_hda_intel
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-2: PipeWire v: 0.3.38 running: yes
ah. it’s called “sound server”. thank you.
But why do I have two sound server?
hi,
here’s the result:
Sound Server-3: PulseAudio v: 15.0 running: no
thank you all for all the help manjaro community.
hello,
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 58
Tile Size: 65472
User Name: ****
Host Name: Manjaro-PC
Server Name: PulseAudio (on PipeWire 0.3.38)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1b.0.analog-stereo
Default Source: alsa_input.pci-0000_00_1b.0.analog-stereo
Cookie: 42d2:7531
it says pulseAudio on pipewire. so it’s a layer only for pulseaudio. thank you.
system
Closed
25 October 2021 11:16
8
