I just installed Manjaro Gnome and didn’t use a password when installing but when I was going to install the software and delete why I was asked for a password and it was always wrong even though I didn’t enter a password when installing and also when locking the screen was also asked for a password and wrong
is there a solution to be able to install without a password
no, linux is a secure system.
there are work arounds though.
like using nopasswd for sudo & creating a nopasswd polkit
I will strongly advise against such setup - it is doable but in this world - being online from the moment you turn your system on - it is a bad choice and you are asking for all kinds of problems - but as it is your system and thus your own responsibility.
Lecture aside
