Hi, I use kde plasma. It shows in the system information that I use x11. I wanted to know how to install wayland and use it
You just have to install ‘plasma-wayland-session’ . From SDDM manager you can choose wayland when you log in, or you can permanently change the settings in system settings (SDDM)
Install plasma-wayland-session. After that you should be able choose Wayland in SDDM during login
what about egl-wayland and xorg-xwayland ?
