recently i got anbox working but it was preety sloow so i want to try out waydroid i have installed the waydorid package and did sudo waydroid -init and but the app wont open so could some one give me a whole tutorial to install it tnx.
You have to meet two requirements to run Waydroid:
- run on Wayland session
- do not run on Nvidia card
Perhaps this might help: Waydroid - ArchWiki
tnx for your reply and help this happned when i tried to start the waydroid sessinon manager it gives me this eror.
XDG Session is not "wayland
how can i set XDG session to wayland?
this doesnt show how to use wayland.
Simplest way is if you use KDE – install plasma-wayland-session and on login screen you need to choose Wayland. Gnome probably have similar way. XFCE going to introduce Wayland support in 4.18. I don’t know other DE.
ok tnx ima try that tnx for the reply
i use xfce i tried but it didnt work i run weston then tried to start waydroid from there but still says XDG session isnt wayland.
I need my nvidia card in use for CUDA/OpenCL and support for apps that probably won’t be transitioning any time soon, if at all (especially commercial/niche apps like SideFX Houdini, TVPaint, OpenToonz, etc). Is there no way to get Waydroid to work with X11/nvidia?
No. It’s Waydroid, not Xorgdroid. ![]()
Then where is Xorgdroid?
