Hi Community, feeling a bit of an idiot, but
…after booting Sway edition in live environment, how can I actually install it? No install launcher as in the official editions (I normally use gnome), what am I missing?
The installer program name is calamares.
In a menu I’d look for install or that as well … is there no welcome screen as in the other iso’s?
… a few minutes later, after booting this iso up and checking:
no, there isn’t a welcome screen - instead:
the installer is already there
it is already present when one boots from USB
it may look like a background image - it is not - it is the installer
any click on the menu top left brings up the launcher - you launch calamares from there as well
hey @romeog
Its a shot in the dark as not sure what’s happening (or not happening), but you might want to try running the installer from the terminal.
When I was trying out Manjaro Sway in VirtualBox, I had a similar issue
Try this:
- Open a terminal
- Copy and paste this command
sudo -E calamares
and fingers crossed ![]()
