Wait, I mean that I’m on Manjaro Gnome, I would like to install third part app and I was wondering which file should I install, for example Sublime Text Editor has these types four types.
And I ask also about the AUR…
Thanks in advance
Click on the “Linux Repos” button and follow the instructions for Pacman.
Click the link to open the AUR website. Specifically look at votes (more = better), and comments. Also try looking at the PKGBUILD, see if anything suspicious is in there.
lemme start by saying the only packages you can deem “safe” are packages from official repo. in cases where official package does not exist, you are on your own. AUR packages atleast has some sort of assurance that it is bound to work, once the package is built in a form installable on (arch, or arch derivative). then comes original author built such as what you’ve mentioned that also might work out-of-the-box.
your options in AUR are;
aur/sublime-text-4 4.4143-4 (+60 3.33)
Sophisticated text editor for code, html and prose - stable build
which seem to have signed packages from author, which is good enough. personally i use some packages same way.
EDIT: the authors method is invasive but workable (puts in their private repo in pacman.conf). on the plus side, you will get updates as soon as it is available from author with a regular pacman update request, with no other intervention required.
