I just install manjaro, I want to install safe exam browser but I can’t find it for manjaro linux. can any one tell me how can I install safe exam browser in manjaro linux?
Hi @rudyjatmiko,
According to Safe Exam Browser (SEB) | Sito didattica Online :
Is SEB compatible with Linux?
SEB is not compatible with the Linux operating system. Safe Exam Browser is available for Windows (8.1, 10 and 11), macOS (from 10.11) and iOS (iOS/iPadOS 11 or later).
We recommend that you temporarily use a computer with Windows/MacOs, if possible. If this is not possible, it is essential to let your teacher know as soon as possible.
And according to this guy on reddit :
it says it won’t work with virtualization.
So your best bet would be something else. Or a small windows partition for this only.
Additionally, this might be of interest; if the OP is using a desktop machine…
You can also try running it with wine or bottles.
I dont think it will run in wine.
The way i read the faq, it seems like the app pretty much takes control of the system to prevent cheating
And that right there, is why I wouldn’t trust it.
Simply, you can’t. It’s Windows-only (sometimes also Mac).
