How to install Realtek audio driver?
Hello, I’m still relatively new to the Linux world, I recently migrated from Ubuntu to Manjaro and I need help with drivers.
Well, first let’s understand my problem, I use a dual boot with Windows, and I’ve always had the problem of my front audio not working. In Windows I managed to solve it by installing the Realtek drivers that I found on the Intel website, but how can I do this in Manjaro?
Welcome to the Manjaro community.
I’m sure someone will help with your issue when they are able.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
If audio to rear jack(s) of motherboard are working, system probably has correct Linux audio drivers installed
Most Realtek onboard audio devices on desktop systems use ALSA module snd_hda_intel
Advanced Linux Sound Architecture - ArchWiki
Loaded modules identification
Run lspci -k -nn -d ::0403 to identify the modules in use for PCI devices.
Run cat /proc/asound/cards to get the list of your sound cards with their corresponding indexes (card numbers).
