Hi,
I’m having difficulties installing NZBGET on Manjaro XFCE.
SABNZBD installed and functions with no problems.
I have searched this forum, and Google, but have not found a clear, and concise answer.
I have also read the Wiki on this topic, but again, it is not clear and concise for me to understand.
Thanks in advance for any help.
Hi nl.smart,
maybe I should edit my post.
NZBGET installs fine, but I cannot open/run it.
I successfully installed SABNZBD, and I can open/run it without any problems.
I just cannot figure out how to successfully install/open/run NZBGET on Manjaro.
I have seen other questions about this on other forums, however, there does not seem to be any answers in layman’s terms.
Thanks
Aragorn
January 21, 2022, 9:43pm
#4
Hi Aragorn,
Thanks for your help.
I was able to open the web interface via the terminal commands on the Wiki, but I have no idea how it happened.
For example: in the Wiki, it states to do the following things:
"Update the configuration before starting NZBGet:
/var/lib/nzbget/.nzbget
WebDir=/usr/share/nzbget/webui
ScriptDir=/usr/share/nzbget/scripts
LockFile=/var/lib/nzbget/nzbget.lock
ConfigTemplate=/usr/share/nzbget/nzbget.conf
DaemonUsername=nzbget
Make sure the permissions are set correctly:
chown -R nzbget:nzbget /var/lib/nzbget
chmod -R 750 /var/lib/nzbget"
How exactly do I do this?
This is the trillion dollar question that would make life so much easier for many Linux users around the globe.
Do have a step by step list of commands that I should input in the terminal to accomplish the above task(s)
thanks for any help
Aragorn
January 21, 2022, 10:33pm
#6
Those are commands, to be executed in a terminal window, and you’ll have to do that with elevated privileges, because /var/lib
is not writable to unprivileged users.
sudo chown -R nzbget:nzbget /var/lib/nzbget
sudo chmod -R 750 /var/lib/nzbget
Thanks Aragorn,
I was able to use NZBGET and download an .NZB file, but I have no idea where the Downloaded/unpacked file is located.
Is there a way to choose the destination of downloaded/unpacked files?
Thanks
Aragorn
January 21, 2022, 11:06pm
#8
If you downloaded it as an ordinary user, then logic dictates it would be in your ~/Downloads
folder.
The documentation should tell you that.
Thanks again Aragorn,
How exactly would I know if I downloaded it as an ordinary user?
Which part of the documentation should I look for downloaded file destination?
Thanks
Aragorn
January 22, 2022, 12:02am
#10
I don’t know how that software works, but presumably you would be downloading those files via a web browser or some other userspace application. It would be the most logical way.
If you read it, you will know.
I am having some problems on Manjaro KDE.
So far, have done the following steps successfully
Edit: Installed from manjaro repository.
~ nzbget -v ✔
nzbget version: 21.1
~ sudo mkdir /var/lib/nzbget ✔
[sudo] password for user:
~ mkdir /var/lib/nzbget/.nzbget ✔ 13s
mkdir: cannot create directory ‘/var/lib/nzbget/.nzbget’: Permission denied
~ sudo mkdir /var/lib/nzbget/.nzbget 1 ✘
~ sudo cp /usr/share/nzbget/nzbget.conf /var/lib/nzbget/.nzbget ✔
~ kate /var/lib/nzbget/.nzbget/nzbget.conf
I followed this (https://wiki.archlinux.org/title/NZBGet#Configuring_NZBGet ). I am stuck here…
https://imgur.com/a/ZjtFCfk
What now ?
probably somewhere in the documentation is mentioned that a new user and/or group nzbget have to be created
The message means that there is no such user and thus the ownership cannot be changed to that user.
so, just after installing… https://imgur.com/a/ofgnvJu
then, did these steps…
~ sudo useradd nzbget ✔
~ id nzbget ✔ 9s
uid=1001(nzbget) gid=1001(nzbget) groups=1001(nzbget)
~ sudo chown -R nzbget:nzbget /var/lib/nzbget ✔
~ sudo chmod -R 750 /var/lib/nzbget ✔ 19s
~ sudo nzbget -c /var/lib/nzbget/.nzbget -D ✔
after the change… https://imgur.com/jVhI1Qz https://imgur.com/YsPtOrL
https://imgur.com/SgiAifK
If those steps were correct, what to do now ?
cyberchaser1:
what to do now ?
… you will eventually notice that none of your links are actual links
and that the second to last one doesn’t go anywhere …?
Sadly, that’s the forum’s policy. I can’t paste/include links in this post.
just as an example I took your post
and changed it
so that the link (and only the link) is formatted as blockquote
This will also work as a new member.
and this is what it looks like with the one I was referring to:
https://imgur.com/jVhI1Qz%20https://imgur.com/YsPtOrL
it goes nowhere
btw: I did not read the documentation or tried setting this up myself
so I cannot really help with whatever issue it is that you have
Hi cyberchaser,
Which specific posts/commands did you use to successfully install and run/open NZBGET?
For example, did you follow “kevinelekiller” post…or a different one?
If you did follow “kevinlekiller” instructions…do have specific instructions on how are steps 1 and 2 accomplished? For example, if my username is “Bob”, what specific commands would I execute ? Thanks
1 . sudo chown "$USER:$USER" "$HOME/.nzbget"
Edit the config file:
2 . nano "$HOME/.nzbget"
“edit the config file”…nano “Home/.nzbget” … how exactly do I do this?
edit is kind of vague.
Thanks
To edit the mentioned file:
nano -w <your home folder>.nzbget
Hi @dude_1776 I have updated that Reddit post. You can check it. I have explained it there. After that if u get any queries I will try to answer.
Good luck.
