hello ,
I installed nerd fonts fira Code from nerdFonts website there are so many files -windows compatible ,otf ,ttf etc.which should I insatll and how should I install for terminal.?
Have you tried nerd-fonts-fira-code in AUR?
oh I am sorry.
for not doing that.
understood thankyou.I will take care next time.
the icons are appearing smaller than the text.
see
how do I make them a little larger
did you select the font you installed in the terminal settings?
yes settings->edit current profile->appearence->font
here use the line characters contained in fonts options is unchecked.
