I just bought a Picoscope oscilloscope and on the forum it says that you need mono-4.4.1.0-1, which is really old. I have tried downgrading it, but pacman says the PGP signature is not valid. What can I do?
The package is 4 years old. Most likely that Arch packager is no longer active and his key is invalid.
Hello!
There is a PicoScope package in the AUR. Maybe try this one? It should work with mono 6.1.
pamac build picoscope
They already helped me out at the AUR. You have to install the libraries for your device and the user to the „pico“ group. Mono wasn’t the problem
