Yzga
January 9, 2022, 2:40pm
#1
Hello, I wanted to install the bautiful theme from the store. And then I get this description. I understand ZERO.
Description:
Materia pack for Plasma 5 desktop.
Please use Kvantum Engine and Theme for better looking:
pling dot com/p/1229126
Install full Materia pack from my collection.
→ Ok. Theres a file to download. Ok. And now? Where is the information, what I have to do? I hope someone can help me. Thanks guys!
Hi!
You can install materia-kde-theme from the repos directly:
sudo pacman -S materia-kde kvantum-theme-materia
As @ishaan2479 said and as is on the GitHub repo:
Or, the distro agnostic method:
Install
wget -qO- https://raw.githubusercontent.com/PapirusDevelopmentTeam/materia-kde/master/install.sh | sh
Uninstall
wget -qO- https://raw.githubusercontent.com/PapirusDevelopmentTeam/materia-kde/master/install.sh | uninstall=true sh
Yzga
January 9, 2022, 3:00pm
#4
Sorry I didnt describe correctly
I already have it and I use it. But I dont have the dock bar at the bottom and all the things
I don’t use this particular theme but it’s a theme, just a theme.
You can add the docks, panels yada yada in Plasma as usual (Right click desktop → Add panel → …), can’t you?
If you want something similar to this then go to Settings > Appearance > Global Theme and check the option Use desktop layout from theme
and before applying.
Yzga
January 9, 2022, 3:12pm
#7
I did exactly, but didnt work. I have the colors etc. from the theme, but the rest is just like standard.
Install latte-dock
and launch it from menu.
Yzga
January 9, 2022, 3:14pm
#9
Yes I can add panels, but I have no option to add a dock like in the picture postet by ishaanbimwal
You can use latte-dock
as @openminded said, or, you can add a plasma panel and resize it to look like a dock (the first one is more functional).
Yzga
January 9, 2022, 3:18pm
#11
Ok that worked, thx, and how can I install the taskbar on the top, like we see in the picture?
Right click on desktop > Add Panel and choose one
You can add a panel anywhere and later move it to top
system
Closed
January 12, 2022, 5:21am
#14
