AFAIK Arch strips the debug symbols from all binaries. If you need static library with debug symbols then is supposed that you know how to compile your own packages with ABS. https://wiki.archlinux.org/index.php/Arch_Build_System
Absolutely you can ask, but that is all i know about this subject, so you will have to wait that someone with more knowledge will respond and give you advice.
