It doesn’t appear to be available in the repo’s. How do I install it?
https://www.freecadweb.org/
https://wiki.freecadweb.org/Install_on_Linux
https://wiki.freecadweb.org/Compile_on_Linux
https://forum.freecadweb.org/viewtopic.php?t=25031
Open pamac (add/remove software) and enable the AUR in the settings. If you search for freecad now you will find it in the AUR.
Thank you very much.
I tried installing it through pacman but it doesn’t seem to support AUR packages.
Pacman does not support the AUR. Use the command
pamac build AURpackagenameHere
Hi
Enable Snap
sudo pacman -S snapd
sudo systemctl enable --now snapd.socket
And go to https://snapcraft.io/freecad and click Install.
Good luck
It is also available as an Appimage.
