I’m still hoping someone would add this to the AUR. In the meantime if someone is willing to explain how to properly install it in Manjaro I’m all ears
Taking a closer look, Crowdsec isn’t really meant to be installed like that. The wizard needs to be run to set it up, for one.
It’s technically possible to install it with a PKGBUILD, but there’s a lot more that needs to be done. See the Debian files for example. Here’s the installed file list.
Yeah that’s what I figured, after building and installing the package, and modifying the service to match the executable path, I still couldn’t start it.
While searching for how to use it I saw the installation wizard process and thought there was some steps missing besides copying the files.
I might give it another try later, I just wanted to try and check my system with it. I’ll probably try their ‘normal’ installation next time.
