JerryC
10 November 2021 20:47
1
Need to install Crossover so I can run some windows programs, Quicken primarily. The Crossover website provides 3 versions of linux to choose from: deb rpm and bin. I guessed I would need bin so I downloaded it. Now, how do I install it? I am an Arch newbie.
JC
Do you actually need Quicken? There are free alternatives.
Crossover is in the AUR: AUR (en) - crossover , so you can install it with pamac build crossover
(Or any other AUR helper like paru
or yay
However, from my understanding, crossover is a paid proprietary software (copy of wine?). Which means, they must have some sort of support channel.
Is crossover
(version 21.0.0-1) not also to be found in the community packages?
Yes, it is in our repos. No need to build it from AUR.
Just use one of these commands: sudo pacman -Syu crossover
or pamac install crossover
This isn’t Windows, no need to go searching for software on various websites. Always search Add/Remove Software first.
system
Closed
13 November 2021 11:57
6
