Specifically I want to install Steam, when I do pacman -S steam
it isn’t found. I also tried to use a flatpak but it defaults to aarch64 and won’t find the package. I am trying to run it through an interpreter, so I just need the binaries installed anyway even if they don’t match my native machine’s architecture.
You can’t install and run x86 native on ARM and that command
is a native ARM comand in your case.
What interpreter? Is it capable to install from other repos?
Maybe you take a look at this https://github.com/ptitSeb/box64 - read their documentation there, and the box64
is in the Manjaro ARM repos, but you will actually need box86
to try to run Steam trough on your ARM device/system.
I still need the steam x86 binaries before running it. I figure there should be a way to still install the x86 binaries from pacman? Pacman doesn’t run steam so it should still work for installing it. For example on Armbian I can do apt install ./steam.deb
and it will install the x86 executables.
Likely pacman does control the package arch=()/$CARCH before installing, but haven’t tried this
pacman will try to install the dependencies, even if you can skip this, the lib32- dependencies doesn’t exit at all
