Hi
I installed the xboard chess game on my pinephone using the discover app and it scales and plays well but i want to play the computer and i don’t know the procedure for adding a game engine. It says that there is none installed when I try to play the computer.
I am using the newest pinephone with the dock and stock os
You can install gnuchess
(which is a game engine).
I have no experience with the Pinephone, but gnuchess
is available on ARM, and it’s in the repo.
One word of caution, though: it plays at grandmaster level.
Thank you.
Would I use?
pamac install gnuchess
pacman -S gnuchess
Either command will do, but if you’re going to use pacman
then you must prefix it with sudo
. pacman
needs to be run with root privileges for installing or removing packages. pamac
will prompt you for a password itself when needed.
Thanks all working
I started the terminal and used
sudo pacman -S gnuchess
entered my root password when prompted and it installed.
xboard chess game used the gnuchess engine without any fuss and the GNOME Chess game now works with the gnuchess engine also.
If everything is satisfactory, then please mark the post that solved your query or best helped you on your way as the solution. That way, a link to said post will be added to the opening post, so that people with a similar question can quickly find the answer.
