I’ve noticed that searching for files in the Activities View really doesn’t work well at all for me.
For example if i search for a filename I know exists “battery” “bug1” “awarob” - the search will NOT find these files.
It seems that some files are searchable, but the vast majority are not.
If I open a NON searchable file (such as the awarob.jpg i mentioned above) if I open it with Gimp or Gthumb & then exit without saving, now it can be searched for.
Music, via lollypop, seems well indexed in the activities search & works as expected. but files / documents do not.
Using tracker3 info $FILENAME in terminal it looks like the files i search for that are not found, are actually indexed. I dont see anything different in the output of a file that is found vs one that is not.
bug1.jpg is found (because i just opened it with Gthumb), bug2.jpg is not found.
tracker3 info '/home/rico/Pictures/PHOTOS-zzz/random pics/bug1.jpg'
Querying information for entity: '/home/rico/Pictures/PHOTOS-zzz/random pics/bug1.jpg'
'file:///home/rico/Pictures/PHOTOS-zzz/random%20pics/bug1.jpg'
Results:
'tracker:extractorHash' = '14aa697c2aff5af87df9512088d50b5e35b696ac3ae79ec91007d612eccbaeb8'
'nfo:fileLastModified' = '2014-11-13T05:22:05Z'
'nfo:fileName' = 'bug1.jpg'
'nfo:fileSize' = '693161'
'nfo:belongsToContainer' = 'urn:bnode:1e5f3fa6-e5d9-4322-9ca0-450f06587238'
'nfo:fileLastAccessed' = '2021-09-02T14:11:00Z'
'nie:isPartOf' = 'urn:bnode:1e5f3fa6-e5d9-4322-9ca0-450f06587238'
'nie:interpretedAs' = 'urn:bnode:84ad2a31-6838-4a87-afc5-b068d86a22d0'
'nie:byteSize' = '693161'
'nie:url' = 'file:///home/rico/Pictures/PHOTOS-zzz/random%20pics/bug1.jpg'
'http://purl.org/dc/elements/1.1/date' = '2014-11-13T05:22:05Z'
'http://purl.org/dc/elements/1.1/date' = '2021-09-02T14:11:00Z'
'nrl:modified' = '866'
'nrl:added' = '2021-08-14T10:29:03Z'
'rdf:type' = 'http://www.w3.org/2000/01/rdf-schema#Resource'
'rdf:type' = 'http://tracker.api.gnome.org/ontology/v3/nie#DataObject'
'rdf:type' = 'http://tracker.api.gnome.org/ontology/v3/nfo#FileDataObject'
tracker3 info '/home/rico/Pictures/PHOTOS-zzz/random pics/bug2.jpg'
Querying information for entity: '/home/rico/Pictures/PHOTOS-zzz/random pics/bug2.jpg'
'file:///home/rico/Pictures/PHOTOS-zzz/random%20pics/bug2.jpg'
Results:
'nfo:fileLastModified' = '2014-11-13T05:22:42Z'
'nfo:fileName' = 'bug2.jpg'
'nfo:fileSize' = '897076'
'nfo:fileLastAccessed' = '2021-09-02T14:11:01Z'
'nie:interpretedAs' = 'urn:bnode:c12955d8-55c5-4a34-9ad0-7c1319960f14'
'nie:byteSize' = '897076'
'nie:url' = 'file:///home/rico/Pictures/PHOTOS-zzz/random%20pics/bug2.jpg'
'http://purl.org/dc/elements/1.1/date' = '2014-11-13T05:22:42Z'
'http://purl.org/dc/elements/1.1/date' = '2021-09-02T14:11:01Z'
What is the issue here?
Manjaro 21.1, Gnome 40
oddly … if i use nautilus & navigate to a folder, I can search & find all direct child files in that folder. for example bug1 & bug2 as above are both found. but it doesnt go to any deeper folders. If I search from /home, only bug1 is found.
Im guessing Activities Search is the same its starting from /home & doesnt go deeper unless a file has been opened with a document viewer of some kind.
