My manjaro partition has lot of space but my tmp/ directory only has 3.8 GB space . Is it possible to increase its space? or should I just not mess around with it?
Hi @Char,
As far as I’m aware, you can’t change that size as it depends on you amount of RAM, seeing as it’s a tmpfs, so in the RAM directly.
If you really want to increase it, I’d suggest buying more RAM.
/tmp is on tmpfs and approximates half your ram. There is usually no reason to change this - exceptional circumstances may warrant it …
You can change this - simply comment the tmpfs assignment in /etc/fstab - save the file and reboot
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
/var/tmp exist in the normal filesystem and is preferred if files need to persist across reboots.
Thank you so much
Commenting out the line — which shouldn’t even be there, because systemd already mounts a tmpfs on top of /tmp even without the entry in /etc/fstab — does not change the maximum size of one’s /tmp. The default is always going to be half of one’s RAM.
tmpfs does however allow one to specify its maximum size via the mount options — see…
man tmpfs
If you want /tmp to have a maximum size of — just as an example — 6 GiB, then you would put something like the following in /etc/fstab. ![]()
tmpfs /tmp tmpfs defaults,noatime,mode=1777,size=6g 0 0
You can also specify a percentage of your RAM instead. So if e.g. you want to reserve 40% of your RAM, you would do something like this… ![]()
tmpfs /tmp tmpfs defaults,noatime,mode=1777,size=40% 0 0
Oh yes it’s so helpful
+1
why you want change ???
In app sometime we can change “cache” directory. For example, we have flags with yay or pamac build for compile big package.
