How to increase font size in LibreOfficeDev using a generic VCL
Hi, everybody,
I am using Mabox (GTK+Openbox Manjaro).
I have to use LibreOfficeDev (libreoffice-dev-bin package, downloaded from the AUR using yay) with a generic VCL plugin. I mean that I start the application using
SAL_USE_VCLPLUGIN=gen /path/to/soffice
I must use that VCL plugin because the developer tags for every string in UI will show only that way (some limitations with gtk3 or kde and gettext that I am far away).
So, in order to read the small font that it shows in my high DPI display, I know that I have to use some key-value pair in ~/.Xresources file (and merge it using xrdb), but then there comes the problem.
I do not know which pair to use. I have tried:
soffice.bin.font: DejaVu regular 12 (just a random example for the font name and size), or
soffice.font: DejaVu regular 12, or
libreofficedev7.6.font: DejaVu regular 12
So, can someone guide me with this issue, please?
NOTE: I do not want to increase the size of ALL applications using:
Xft.dpi: 96
…because it will break my layout/setup for the rest of my GTK-applications.
Well, I finally found out.
It’s better to start the program from the command-line, using some environmental variables:
SAL_USE_VCLPLUGIN=gen SAL_FORCEDPI=144 /opt/libreofficedev7.6/program/soffice
You can experiment with DPI value.
