How to identify log record errors?
Hello friends from the Manjaro community.
Today, when I turned off the computer, I was able to notice that a message appeared on the terminal containing the message [Failed], however, I couldn’t read everything, precisely because the computer turned off right away.
Is there any way I can identify what this error is, and other errors (when turning on the machine), so I can try to fix them?
  Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=4c99a061-31b7-445a-ad39-2ef99ad4a052 rw quiet udev.log_priority=3
  Desktop: LXDE 0.10.1 info: lxpanel wm: Openbox 3.6.1 vt: 7
  Type: Desktop Mobo: INTEL model: H81 serial: <filter>
  UEFI: American Megatrends v: 4.6.5 date: 10/21/2020
  RAM: total: 7.72 GiB used: 1.44 GiB (18.7%)
  Info: Dual Core model: Intel Pentium G3250 bits: 64 type: MCP arch: Haswell
  family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 3 MiB
  bogomips: 12777
  Speed: 3193 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 3193 2: 3187
  Flags: abm acpi aperfmperf apic arat arch_perfmon bts clflush cmov
  constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
  ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
  invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
  pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep ss ssbd sse
  sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
  tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67ef
  class-ID: 0300
  Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati
  unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 506x570mm (19.9x22.4")
  s-diag: 762mm (30")
  Monitor-1: HDMI-A-0 res: 1920x1080 hz: 75 dpi: 82
  size: 598x336mm (23.5x13.2") diag: 686mm (27")
  Monitor-2: DVI-D-0 res: 1920x1080 hz: 60 dpi: 69
  size: 708x398mm (27.9x15.7") diag: 812mm (32")
  Device-1: Intel 8 Series/C220 Series High Definition Audio
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  class-ID: 0403
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
  vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  chip-ID: 1002:aae0 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
  class-ID: 0200
  Local Storage: total: 223.57 GiB used: 10.18 GiB (4.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
  size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: SSD serial: <filter> rev: 61K1 scheme: GPT
  ID-1: / raw-size: 223.27 GiB size: 218.77 GiB (97.98%)
  used: 10.18 GiB (4.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 4c99a061-31b7-445a-ad39-2ef99ad4a052
  used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 84A3-A666
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0
  Device-1: 3-9:2 info: Dell KB216 Wired Keyboard type: Keyboard,HID
  power: 100mA chip-ID: 413c:2113 class-ID: 0300
  Device-2: 3-10:3 info: [Maxxter] Optical Gaming Mouse [Xtrem]
  type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0301
  Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 42.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1216
  Processes: 157 Uptime: 45m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 657 lib: 154 Shell: Zsh v: 5.8
  running-in: lxterminal inxi: 3.3.06
Try
journalctl --boot=-1
to see the log from the previous boot (-1)
Also see This Arch article about journalctl
:crossed_fingers:
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
