How to identify and separate standalone applications from libraries in Linux package lists?
I want to generate a list of trending Arch/AUR packages that focuses on user-facing applications rather than background libraries and dependencies.
I wrote a script that uses the data from pkgstats to show non-dependency packages sorted by popularity. However, it doesn’t distinguish between applications and libraries, so the output isn’t very useful.
I want to identify and separate standalone applications from libraries and dependencies for both Arch official repositories and AUR packages. Not just for installed packages but for all of them.
pamac, Graphical Package Manager for Manjaro Linux with Alpm, AUR, Appstream, Flatpak and Snap support, seems to identify applications vs libraries/dependencies when grouping packages into categories like “Music & Audio” or “Games”. As seen in this code, pamac gets categorized package lists and populates the UI accordingly.
Since it may not be clear what libraries or dependencies are and I’m already using pamac as an example. I’ll consider packages that appear in pamac’s categories like Games and Music & Audio as applications, and other packages as libraries/dependencies.
As an alternative, I would consider end-user software the ones that aren’t required by any other packages. This isn’t perfect, just good enough. For example, this is how I would do this for installed packages.
How can I identify standalone applications and separate them from libraries/dependencies in the Arch/AUR package lists? The end goal is a trending packages list focused on end-user software rather than background components.
It uses the information from AppStream data I think.
Look for AppStream metadata files like .desktop and .metainfo.xml. Presence of these suggests the package provides a graphical application.
I want to check all the packages in the Arch/AUR repositories, not just installed packages.
To get a list of all installed Arch/AUR packages that aren’t libraries or dependencies, i.e., they aren’t required by any other packages, you can use the pacman command with the -Qent flag. This will list all explicitly installed native packages that are not direct or optional dependencies:
pacman -Qent
However, this command will only list packages from the official repositories and not the AUR packages. To get a list of all installed AUR packages, you can use the pacman -Qmq command:
pacman -Qmq
To filter out AUR packages that are not required by any other packages, you can combine the output of the above commands with some additional scripting. Here’s an example of how you can achieve this:
comm -23 <(pacman -Qmq | sort) <(pacman -Qqg base | sort -u)
This command will list all installed AUR packages that are not required by any other packages. Note that this command assumes that you have the comm utility installed on your system. If you don’t have it, you can install it by installing the coreutils package:
sudo pacman -S coreutils
Keep in mind that this approach might not be perfect, as it may still include some packages that are indirectly required by other packages. However, it should give you a good starting point for identifying packages that are not libraries or dependencies.
See:
appstreamcli list-categories "Productivity"
appstreamcli list-categories "Games"
appstreamcli list-categories "Audio"
appstreamcli list-categories "Music"
appstreamcli get firefox.desktop
appstreamcli dump firefox.desktop
Appstream is basically what pamac uses here to identify standalone applications.
Without appstream, and using the “find .desktop files” approach, this seems pretty close:
pacman -Ql | grep "\.desktop$" | sort -u -k1,1 | awk '{print $1}'
:golf:
pacman -Ql | grep "\.desktop$" | awk '!a[$1]++ {print $1}'
or
sudo pacman -Fyx "\.desktop$" | awk '!a[$1]++ {print $1}'
Though, of course thats not the AUR.
