Hello,
“mobile broadband connection” is disabled by default in GUI of network setting.
But “Mobile Broadband Unavail…” shows in the Gnome indicator and looks annoying.
There are the two solutions:
both solutions did not help me.
Hello,
Solution:
sudo systemctl stop ModemManager.service
sudo systemctl disable ModemManager.service
Solution:
remove sudo pacman -R modemmanager
