Hi there. I noticed with Manjaro XFCE when i open a 2nd application it will show up to the left of the first one opened in the panel. When i say panel i mean the bar at the bottom which you click on to switch between apps. I constantly get confused because im used to other linux distros and windows having the new one open to the right.
I tried looking at options and there was nothing to change that. any help would be appreciated.
Many thanks. you were spot on. i had to change it from “group title” to “timestamp”. If anyone has problems with finding window buttons just double click where it says “window buttons” to open the menu.
