How to give postgres snap access to my data?
I installed the postgres10.4 snap and I want to start it with a certain data directory where the database is located. But I fail to do that.
postgresql10.postgres -D ~/db/data
WARNING: cgroup v2 is not fully supported yet, proceeding with partial confinement
postgres: could not access directory "/home/tk/db/data": No such file or directory
Run initdb or pg_basebackup to initialize a PostgreSQL data directory.
I tried several ways and I seem to not understand some concepts here. Also no documentation on the snaps webpage.
I tried to be smart by letting it create a db itself and search for it, but this also failed.
postgresql10.initdb -D test_pg
The files belonging to this database system will be owned by user ā€œtkā€.
This user must also own the server process.
fd test_pg /
fd found nothing
Ok, I found /home/tk/snap/postgresql10/current and indeed, if I create a folder there, I can try to start the DB from that.
But I can not copy my DB into that folder as it is too big and on another partition.
I tried a symbolic link, but seems like snap just ignored itā€¦ So still no solution.
Why donā€™t you install postgresql 13.4-1 from the normal Manjaro repo?
I found a solution. Apparently snap only allows access to paritions that are mounted under /home/
So I mounted the partition there and then the symbolic links mentioned above did work.
But then I got other issues, the locale was not set and the db still didnā€™t start up, so I ended up compiling the source myself, which luckily was staight forward.
Download & extract src
./configure
make
make install
useradd -m postgres
I need that version
Then simply remove the SNAP version, and install the ā€˜regularā€™ one.
I did not find 10.4 in the repos other than as snap. Even with the downgrade tool I could only go as low as 11
Oh, I see, you meant ā€œThe reason I dont use the repo package is because I need a different versionā€, not ā€œyes, I need the version in the repositoriesā€
ā€¦ soā€¦ why do you need an outdated version ?
Itā€™s a weird fetish of mine. Ever since Ubuntu 10.4 Iā€™m drawn to that version number :heart_eyes:
Joke aside. I need to do some upgrade tests on an existing serverā€™s database that runs on that version.
Then it would make more sense to use docker instead of snap. Or does your server also run the snap version of postgres?
