Pretty simple question to which I can’t seem to have an answer online: I have an xbox one controller plugged in via USB and the controls work just great! However, the lights inside the controller don’t seem to be working at all. When plugged into a Windows PC, it has a button on the back that switches between different preset light colors, so I assumed that all of the hardware / software for controlling the lights was in the controller itself, but given that it doesn’t work on Manjaro, I might be mistaken.
Here’s the info from inxi about the controller specifically:
I don’t have an XBOX controller to test, but you could try installing game-devices-udev if you don’t already have it installed. It’s required by our steam package, so you might already have it installed.
Reload udev rules after installing it (if applicable):
